Mrshilov
Posted: Wed Feb 26, 2014 2:03 am Post subject: SIEMENS-AX75 LCD library |
Library for Siemens-AX75 (AX72, AX76) color LCD. Resolution 128x128, serial interface, controller LDS183. Library works in 16-bit color.
Test example in attachment.
 [/URL] |
Posted: Tue Mar 04, 2014 1:20 pm Post subject: |
Dear Mrshilov,
thank you again for sharing your work. It is great that you put so much effort in supporting the various lcd's. It is good to see you include circuit and examples as well. For a new comer it might be hard to chose the right LCD with so many to chose from. Maybe you can write some day a small piece of text which LCD you would chose based on your experience. _________________ Mark |
mhal
Posted: Sat Mar 08, 2014 6:00 pm Post subject: |
Mr. Mrshilov
Do you have any similar library for LCD Siemens S65 (LS020 controller)?
Thank you for previous libs.
mhal |
Mrshilov
Posted: Sat Mar 08, 2014 6:17 pm Post subject: |
I have this display. Library is in work, soon to be completed. |
Mrshilov
Posted: Wed Apr 02, 2014 1:37 pm Post subject: |
Mr. Mhal, can you test beta version of library for LS020?
On chips with <=64k it works fine, but on chips >64k works with some strange. On my test PCB with AT90USB1286 I must set RAMPZ=1, otherwise it will not work at all. |
Posted: Wed Apr 02, 2014 1:53 pm Post subject: |
hi Mrshilov,
the reason is simple : you need to call a routine that will set rampz properly.
after you load Z to code in flash you add this code :
Code: | #IF _ROMSIZE>65536
*call _SET_RAMPZ
#ENDIF
this will set rampz to the proper value. _________________ Mark |
mhal
Posted: Thu Apr 03, 2014 10:09 am Post subject: |
The library works very well, but after the modification given by Mark.
I tested it on ATmega16 and ATmega2560.
Mrshilov, Mark, thank you very much.
mhal |
Posted: Thu Apr 03, 2014 11:11 am Post subject: |
maybe you can post the modified version. it will save Mrshilov work. _________________ Mark |
mhal
Posted: Thu Apr 03, 2014 11:59 am Post subject: |
Here is a modified library.
It works for sure with ATmega16 and ATmega2560.
mhal
Modification is below, from Mark.
Mrshilov
Posted: Thu Apr 03, 2014 12:22 pm Post subject: |
Thanks Mr.Mhal.
I did the same modification. My friend test it on Mega128 - all works, but 16-bit picture don't show - black box. This picture shows via external Sub in example. Have you same trouble? |
Posted: Thu Apr 03, 2014 12:39 pm Post subject: |
the lib was not correct. here is one i checked and corrected. _________________ Mark |
Mrshilov
Posted: Thu Apr 03, 2014 2:50 pm Post subject: |
Thanks Mark! Now it fully works.  |
boeseturbo
Posted: Thu May 08, 2014 8:43 am Post subject: |
anybody know where I can order some samples of this displays brand new? I only find used ones :/
Cheers |
Mrshilov
Darthinvader
Posted: Fri Jul 10, 2015 12:59 pm Post subject: |
Hi MrShilov. Is there posibility that you make some corrections so it would work with C65, 130 x 130 LM15sgfnz15? I guess there is S6B33B2.
Someone said that it's clone of 6100 but it didn't work.
I was trying to change something but nothing works Sad |
