Debu
Posted: Wed Feb 23, 2011 10:13 am Post subject: |
Hi friend
Luciano
I need your help
Debu |
compurap
Posted: Fri Feb 25, 2011 11:05 pm Post subject: |
MR RADAM:
In your KEyboard HID example is mising a .bas to compile, please check it if you can.
Really thanks |
radan
compurap
Posted: Sun Feb 27, 2011 2:19 am Post subject: |
file "Const_swusb-includes.bas" is missing...
THANKS |
ollopa
Posted: Sun Feb 27, 2011 12:33 pm Post subject: |
I'm still job-hunting full-time. I'm going to have to take a job out of the area and move, so it will be at least a few months before I do anything USB or BASCOM related. Sorry  |
radan
compurap
Posted: Mon Feb 28, 2011 11:02 pm Post subject: |
Thanks radan...
Last question... Can you trslate to english this coments:
"Dim Resetcounter As Word
Dim Idlemode As Byte
Dim Flaginputmsg As Byte 'Флаг срабатывания таймера
Dim Keymsg( As Byte 'Передаваемый репорт (8 байт)
Dim Key(35) As Byte 'Массив состояния клавиш
Dim Lastkey(35) As Byte 'Массив предыдущего состояния клавиш
Dim K As Byte 'Счётчик цикла сканирования клавиш
Dim Paus As Byte 'Пауза между передаваемыми символами
from your program.... THANKS |
radan
Posted: Tue Mar 01, 2011 6:47 am Post subject: |
compurap wrote: | Thanks radan...
Dim Flaginputmsg As Byte 'The flag timer
Dim Keymsg( As Byte 'The broadcast report (8 bytes)
Dim Key(35) As Byte 'An array of key state
Dim Lastkey(35) As Byte 'An array of the previous key state
Dim K As Byte 'Loop counter scan keys
Dim Paus As Byte 'Pause between transmitted symbols |
compurap
Posted: Tue Mar 01, 2011 4:19 pm Post subject: |
thanks Radam.
I will try and experiment.
Check your schematich included in .bas it said cristal is 12 MHZ and declare a 15MHZ in program. I read your page and know it 15MHZ only to inform...
Thanks and excuse my english. |
compurap
Posted: Mon Mar 14, 2011 10:32 pm Post subject: |
Radan: I cannot make your HID example...
Do you please explain FUSES used to me...
Thanks |
radan
compurap
Posted: Tue Mar 15, 2011 9:38 pm Post subject: |
Thanks Radan.
It work...
...But only in old or linux machines. Not work in win XP and Seven.
Do you please tell me your test machine...
Thanks |
radan
Posted: Wed Mar 16, 2011 6:36 am Post subject: |
WINDOWS XP SP2 |
compurap
Posted: Fri Mar 18, 2011 3:14 pm Post subject: |
I solved, thanks Radan.
The problem was power to avr son in new machines device was not recongnised.
I surfed the web and found your forum in russian...
So i take away zener diodes and put a regulator and power ATMEGA8 with 3.3 Volt and works in all machines.
It was figure 2 from 56740f9d34d1.jpg from your forum |
ex4
Posted: Tue Mar 22, 2011 5:16 am Post subject: |
can i receive or send more than 8byte at a time?
or the max packet size is only 8 byte at atime? |
