six1
Posted: Sat Jun 28, 2014 6:44 am Post subject: |
Amazing Thanos! Keep the good work going on. _________________ For technical reasons, the signature is on the back of this message. |
anatom
Posted: Tue Aug 26, 2014 2:34 pm Post subject: |
wiki link -> "Page not found error"? |
Netzman
Posted: Wed Aug 27, 2014 12:15 pm Post subject: |
there are some changes on the web server, it should be back on the weekend! The download link is still up: Current v1.4
Thanos, that's really a nice project, i'd also like to have such a seat
regards _________________ LCD Menu | Proportional Fonts |
tronicgr
Joined: 22 Apr 2009 Posts: 17 Location: USA, San Diego
Posted: Wed Aug 27, 2014 6:57 pm Post subject: |
Netzman wrote: |
regards |
Hi Netzman,
Its a project about an expensive hobby, but what hobby isn't? Most of the people into this are already into simulators (flight/racing) with really expensive computers. Adding motion to the simulation is just the cherry on the cake
See here another happy simmer:
http://6dofabi.blogspot.co.uk/2014/07/and-testing-after-tuning.html
These days I'm experimenting with real servomotors (not the big AC motors) that are simply amazing. See a piece of the testing I did after coding the interface:
https://www.youtube.com/watch?v=9CMIPu3t7d0
Anyway, I hope your LCD project became more versatile and faster. I remember I had trouble using it along some interrupts. I think I may have to use it later for the UI designer, as currently I have to create the entries manually on my LCD menu.
https://www.youtube.com/watch?v=sRZf0N7hLMM
https://www.youtube.com/watch?v=xEdJDHd_pv0
Thanks
Thanos _________________ Visit my blog about 6DOF controller electronics
http://motionsim.blogspot.com/ |
Netzman
Posted: Sun Aug 31, 2014 3:09 pm Post subject: |
I think, there are things less worth to spend the money at
The motor looks quite powerful, is it running on DC? I can't see any power electronics in your video
Could you describe how your menu structure differs to make it work with the update rate?
In my code, the main display routine contains a bunch of Lcd commands, they take some time, but the Lcd only gets updated when something has changed.
The menu itself also doesn't use interrupts (however in the samples the timer library is used to update displayed values regularely, but you can implement this timing behaviour yourself. there was a bug in the library, a used register has not been saved in the isr, maybe this was causing your problems?).
Maybe the way you solved the problem points me to the right direction, but at the moment I can't see much potential to speed it up while keeping it versatile...
Best regards,
Matthias _________________ LCD Menu | Proportional Fonts |
tronicgr
Posted: Wed Sep 03, 2014 7:27 pm Post subject: |
Hi Matthias,
I actually use that servomotor for my DIY FFB steering wheel:
https://www.youtube.com/watch?v=phHcsRGeF5U
Its BLDC integrated servomotor that runs on 75volts (has the power drive and position controller inside the motor). The power supply for it is on the floor, weights 6kg!!!
https://www.dropbox.com/s/hznc6h799gaf714/IMG_20140903_072007_791.jpg?dl=0
I don't really have much time to describe the menu structure exactly, but I can say I use flags to indicate when the LCD needs to be updated, and counters to slow down the automatic refresh of the display depending on the load of the processor. The menu is actually not central structured, and half of it resides in an interrupt routine that activates when I use the quadrature encoder...
I hope I can strip down an example code part for you, if I get some free time.
Thanks
Netzman
Posted: Tue Nov 21, 2017 8:18 pm Post subject: |
LCD Menu V. 1.5
Enhancements:
* Added option to preserve editable values in EEPROM
* Changed file extensions from .bas to .inc
* Added menu entry move up/down buttons
Bug fixes:
* Exported wrong count of values of type Long
* Exported wrong data for Dword data types
* Minor bug fixes
Download: http://mat.midlight.eu/index.php/Simple_LCD_Menu_Main_Page#Download
Older versions should receive an update notification on startup.
br _________________ LCD Menu | Proportional Fonts |
Posted: Tue Nov 21, 2017 10:01 pm Post subject: |
Hello Netzman,
Thank you for the update and support. _________________ Mark |
