Bugs and solutions - new and historic
Post new topic   Reply to topic    www.mcselec.com Forum Index -> KokkeKat FAT-free SD card lib
KokkeKat
PostPosted: Mon Jul 11, 2011 12:35 pm    Post subject: Bugs and solutions - new and historic Reply with quote
There is a v1.0 bug in Sdcreatefileordir:. Add the two lines (at about row 1400) I have highlighted below:
      ' An available (previously erased) directory entry or EOD End Of Directory marker found
      ' Sddirclusterd, Sddirsecincluster, and Sddirbufferpos now point to this directory entry
      If Sdstatus = 28 Or Sdstatus = 32 Then                ' Free directory entry found
         Sdstatus = 0                                       ' Remap Sdstatus
         ' Find free FAT1 entry and store position in Sdfatsectornum, and Sdfatbufferpos plus Sdfatclusterd
         Sdsectord = Sdfatsectornum                         ' Continue looking in the same FAT sector
         Sdbufferpos = Sdfatbufferpos
         Gosub Sdfindfreefat
         If Sdstatus = 0 Then
            Gosub Sdlocatedirsector                         ' Point to the available directory entry again
            Sdsectord = Sdsectord + Sddirsecincluster       '<--- new line
            Decr Sdsectord                                  '<--- new line
            #if Sdwmode = 1
               Sdreaddestination = 0
            #endif
            Gosub Sdreadsector
This bug is fixed in v1.2 of the library that is published in sticky thread "Latest release".
KokkeKat
PostPosted: Sun Sep 11, 2011 3:46 pm    Post subject: Reply with quote
There is a v1.0 bug in the library. It's in Sdcreatefileordir, around line 1344 in KokkeKat_FAT-free_SD_lib_code.bas:
  Gosub Sdwritesector
     Sdsectord = Sdsectord - Sdfat1location       ' <--- change to this
     Sdsectord = Sdsectord + Sdfat2location
     Gosub Sdwritesector
KokkeKat
PostPosted: Sun Oct 30, 2011 9:49 pm    Post subject: Reply with quote
Hi
This doesn't really qualify as a bug, but please note that you must make sure to set Sdstatus to 0 before calling Sdreadfsinfo or Sdwritefsinfo.
Otherwise, you will have a timeout problem after Sddirlistdelete, that ends with Sdstatus being 31 when successful. (Most other routines end with Sdstatus being 0 when successful.)
Kind regards
Niclas
KokkeKat
PostPosted: Sun Jul 22, 2012 8:46 pm    Post subject: Reply with quote
Please make sure to initialize all variables before starting a new file operation. Many thanks to Benoit for reporting the below:
"sdeof must be set to 0. sdbytesread must be set to 0 at the begining otherwise when you reenter the file eof is directly set to 1 because sdbyteread not reseted and file end is reached."
This affects Example_FIND_READ_FILE and Example_DIRLIST_READ_FILE (and possibly also other examples).
Kind regards
Niclas
Post new topic   Reply to topic    www.mcselec.com Forum Index -> KokkeKat FAT-free SD card lib All times are GMT + 1 Hour
