Posted: Sun Jul 10, 2011 9:38 am Post subject: Single variable, different value between input and output ?
Hi all,
I am sorry if my question has ever be asked.
I have input value with single variable and then saving to eeprom, but after I print this variable or read it from eeprom, this value is different with input value.
first of all you use a very old version. but for the problem this does not matter.
you need to read the help topic about SINGLE variables.
Essential, you can not store every number exactly into a single. So the problem will be when you read it or print it.
Some values can be stored exactly, like 0.0 but most number with fractions not.
Use a double for more precision, or a long and scale it.
This is a problem related to single precision numbers.
if you try this on your calculator : 1/3 and you mul by 3 the result will not be 1 either. _________________ Mark
Thank you for your advice.
I already try with double variable and it's OK for small code.
But when I try at my huge code which achieves 70% capacity of Atmega32, then error message appears after compiled:
"Error 220: Line: 1730 Forward jump out of range [_STR2BYTE] ...."
Line: 1730 points to end of code line, it means it does not point to specific code so I don't know which code is problem.
Do you know what problem is ?
Also another snippet code:
B = 2 + Int(A)
If A and B are Single, this code is OK, but if A and B are Double, the code will be error so it has to be changed to 2 code lines:
