Disabling HW-UART with not using $baud (solved)
laborratte
PostPosted: Mon May 30, 2011 6:18 pm    Post subject: Disabling HW-UART with not using $baud (solved) Reply with quote
I recently disabled the HW-UART (when pins needed for other stuff) just by not using the statement
$baud=9600 'or whatever for baudrate needed
Now with version 2.0.5.0 I got the error message
Error : 70    Line :   996   BAUD rate not possible [-32768]  , in File ...
until I write the $baud statement in my code - which introduced the not wanted UART-setup.
Is this an new feature or a bug?
P.S.
I know how to disable the UART by hand with
UCSR0B.RXEN = 0
UCSR0B.TXEN = 0
I just want to know if I have to change that on my existing programs....
ajvuik
PostPosted: Mon May 30, 2011 6:48 pm    Post subject: Reply with quote
I recently played around with UART in a Mega8. Are you trying to do something with the soft UART? I don't know for sure of-course, because I don't know the rest of your code, but you could try:
baud = 9600
instead of:
$baud = 9600
the second code will invoke the hardware UART if your chip has one, the first is just a statement indicating how fast you want a serial communication to work.
Atleast, that's how I understand it from the help files.
some one with more knowledge will correct me if I'm wrong.
regards
laborratte
PostPosted: Mon May 30, 2011 7:10 pm    Post subject: Reply with quote
I don't want to use UART at all. I need the pins for other stuff.
I think most people want to use the UART so Bascom's normal behavior is to prepare the UART and using the value given in $baud fot baudrate. Till now I could disable the UART just by commenting $baud out. Then the compiler didn't include the UART setup. This seems to be changed now.
PostPosted: Mon May 30, 2011 7:59 pm    Post subject: Reply with quote
it was not changed. I can not reproduce it either.
best to send a zipped sample to support.
mattcro
PostPosted: Mon May 30, 2011 8:10 pm    Post subject: Reply with quote
If you don't specify $baud in your code, the compiler uses whatever is set in the compiler options (Options>Compiler>Communication). If you have a silly value set here (like "1") then the compiler can't calculate the required baud divisor value and fails with that error.
Note that the compiler doesn't actually generate any UART code unless you put $BAUD in your code or use PRINT, INPUT, etc.
If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.2
Visovian
PostPosted: Tue May 31, 2011 5:07 am    Post subject: Reply with quote
But it still occupies tx and rx pins. To release them use
UCSRB = 0
PostPosted: Tue May 31, 2011 9:31 am    Post subject: Reply with quote
This statement is wrong. If the code doesn't contain anything serial-related, the UART isn't connected to the pins and they have their normal function.
laborratte
PostPosted: Tue May 31, 2011 1:03 pm    Post subject: Reply with quote
Sorry, I forgot to say that I'm not using the IDE. The following code is working under 1.11.9.5:
'Program "baudtest.bas"
$REGFILE    = "m128def.dat"
$CRYSTAL    = 8000000
$FRAMESIZE  = 32
$HWSTACK    = 10
$SWSTACK    = 40
'$BAUD       =  9600  (commented out)
do
loop
Compiling with command
bascomp.exe baudtest.bas SS=40 FR=32 HW=10 CHIP=20
Under Version 2.0.5.0 and (just tested) 2.0.6.0 the error message
Error : 70    Line :   16    BAUD rate not possible [-32768]  , in File : ...Baudtest.bas
is generated.
OS is Win7 x64.
PostPosted: Tue May 31, 2011 2:56 pm    Post subject: Reply with quote
It was caused by a change in the report module. I changed it.
laborratte
PostPosted: Tue May 31, 2011 4:09 pm    Post subject: Reply with quote
Mark,
thank you. As always in the last 10 years: perfect support!
Very Happy
athomeelectronics
PostPosted: Tue May 31, 2011 7:38 pm    Post subject: Reply with quote
Albert,
recently, there was also something wrong with baud rate error calculation on Xmega chips (report said 100% error or something). That was corrected, thanks for that.
But, there's still always error "High Baud rate error in line 0".
You can test this with code:
$regfile = "xm128a1def.dat"
$crystal = 32000000
$lib "xmega.lib"
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
Config Com4 = 38400 , Mode = 0 , Parity = None , Stopbits = 1 , Databits = 8
Open "COM4:" For Binary As #4
NOP
Print #4 , "abc"
PostPosted: Tue May 31, 2011 8:31 pm    Post subject: Reply with quote
The name is Mark, not Albert (Alberts is my sure name) Smile
This was a warning, I changed it.
Visovian
PostPosted: Wed Jun 01, 2011 6:38 am    Post subject: Reply with quote
MWS:
You are right.
I had tested it in some wrong way.
athomeelectronics
PostPosted: Wed Jun 01, 2011 6:56 am    Post subject: Reply with quote
Thanks for changing that, Mark Smile
