There is nothing in the Help file that would suggest the use of a plus sign (at least I can not find any).
If you replace it with a semicolon then it works.
It also works if you use a separate print command for CHR(X).
Hubert
This change in behaviour may be due to a bug fix related to strings:
History.txt for 2.0.6.0
- using {034} and quotes gave a problem when they were unbalanced.
The correct way to print multiple variables is to use the semicolon. The contatenation (plus sign) seems to give odd results sometimes. _________________ If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.5
