Dim Count_units As Byte , Times As Byte , Flag As Bit
Dim W As Word
Times = 5
Const Timer1reload = 7 '1 ms
Config Timer1 = Timer , Prescale = 1024
'Load Timer1 , Timer1reload
Timer1 = 65536 - Timer1reload
On Ovf1 Timer1_isr
Enable Timer1
Stop Timer1
Start Timer1
If Flag = 1 Then
Print " end of Timer1 "
W = Timer1
Timer1_isr:
Incr Count_units
Print " Hello Timer1"
Start Timer1
If Count_units >= Times Then
Stop Timer1
Count_units = 0
Flag = 1
I have problems with the 16 Bit Timers on the Atmega640
On the Simulator
The Timer1 works
The 8 bit Timer2 works with max 64 prescaler
and the Timer3, Timer4 and Timer5 donīt work
I have found this code from you but that donīt work too on the Bascom Simulator.
Have you a explanation why this happens?
$regfile = "m1281def.dat" 'register file for MEGA128-16
$crystal = 16000000 '16MHz crystal
$baud = 9600
$baud1 = 9600
$hwstack = 80 '64 ' default use 32 for the hardware stack
$swstack = 80 ' default use 10 for the SW stack
