how to change source in C for ATmega 8
jempie
PostPosted: Mon May 16, 2011 11:41 am    Post subject: how to change source in C for ATmega 8 Reply with quote
I have the source of an program witch is written in C use for ATmega 8
i thought it only work with bascom but it work also in C
now i want to change the source but i only have AVRISP and the software
can i read the source into AVR studio and make an HEX file.
I'm totally new in programming, but i want to try this
Thanks
PostPosted: Mon May 16, 2011 11:57 am    Post subject: Reply with quote
This forum is not for C projects.
You should know that since this is not your first post.
Try avrfreaks or some winavr forum.
mcselec.com is dedicated to BASIC, not C.
If you need help converting C to BASIC it is ok. But help for C projects is out of scope.
jempie
PostPosted: Tue May 24, 2011 12:40 am    Post subject: Reply with quote
Sorry for that.
OK I have an schematic and I want this work bascom
I'm totally new in programming but i want to learn this.
See schematic i now have change this source first step
does i forget something?
******* source***************
$regfile = "m8def.dat" ' specify the used micro
Config Portb = Output
Dim Address As Byte , Command As Byte 'RC5 ir variable
Dim W As Word
Dim Inp_sel As Word
Dim Pwr As Bit
Declare Sub Shiftlf 'name say all for subroutine ...doh!!
Declare Sub Shiftrt
Declare Sub Volup
Declare Sub Voldn
Config Timer1 = Timer , Prescale = 1024
Stop Timer1
Config Rc5 = Pind.7 'pin where is conected ir senzor 'backlight on
Portb = &B00111111 ' PORTB.2 and PORTB.3 motor control lines for alps pot
Portc = &B00111111 ' PORTB.2 and PORTB.3 motor control lines for alps pot
Inp_sel = 0 ' 0 =mute , 1 = normal
Start Timer1
If Pwr = 1 Then
W = Timer1
If W => 156 Then
Set Portd.3
Set Portd.2
Getrc5(address , Command) 'read if we have remote ir command remote work on 17
If Address = 17 Then
Command = Command And &B01111111
Reset Portd.6
Select Case Command
'---- this codes are for my remote , change code to your suit ! ----------------
Case 52 : 'Call Shiftlf 'remote command code for CH up
Case 50 : 'Call Shiftrt 'remote command code for CH down
Case 32 : 'Call Volup 'remote command code for Vol +
Case 33 : 'Call Voldn 'remote command code for Vol -
Case 180 : 'Call Shiftlf 'remote command code for CH up
Case 178 : 'Call Shiftrt 'remote command code for CH down
Case 160 : 'Call Volup 'remote command code for Vol +
Case 161 : 'Call Voldn 'remote command code for Vol -
Case Else : Set Portd.6
End Select
If Pwr = 0 Then
Select Case Command
Case 140 : 'Call Pwronof
Case 12 : 'Call Pwronof
End Select
