As can seen at Case 20.. it works propperly to give out the text: 1 on..
Only if i try to controlinduvidual a port.. It won't work. Maybe somebody can tell me why i can't control the ports? _________________ Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
Posted: Wed Jul 21, 2004 8:23 am Post subject:
Doesn't work either.. The case statement works fine.. Because if i hit 33 it gives me the NOT FOUND error.. but the controll of the port doesn't work yet.. _________________ Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
Portb=255'had to do this with the AVR Development board Do Getrc5(baddress , Bcommand)'recieving data from ir eye
'----------------------------------------------------- '|Starting of build-in code analyser for RC5 '|Baddress and Bcommand can be readout with terminal programm If Baddress <255Then'< otherwise terminal output will be continue 255 255 when no data send Print Baddress ;" "; Bcommand 'gives readout on terminal End If
If Baddress =21Then'checks for valid address SelectCase Bcommand 'set or resets the output pins when there is a command
The code is made for a 90s2313 and recieve rc5 and will controll 4 relays.
A scheme will posted later when i finished that part. _________________ Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
