interrupt problem
hast66
PostPosted: Fri Aug 26, 2005 3:27 pm    Post subject: interrupt problem Reply with quote
Hi
On PIND.3 of a 90S2313 I connect a pushbutton and I use this as an interrupt
Every time I push short the prg should wait 1500sec. When I push longer(>1sec) it should go to the ISR "RESETTEN"
Config Portd = Input
Reset Portd
Config Int0 = Falling
Config Int1 = Rising
Enable Int0
Enable Int1
On Int0 Resetten , Nosave
On Int1 Uitstel , Nosave
'main program
‘something with some wait instructions in between
'ISR 1 rising uitstel
Uitstel:
         Wait 1
         Enable Int1
         If Pind.3 = 0 Then
                              Wait 1500
                              Goto Resetten
         Bitwait Pind.3 , Reset
         Goto Resetten
'ISR 0 falling resetten
Resetten:
         jmp 0                                            ' soft reset
End                                                         'end program
when I push short the prg goes to the wait 1500 instruction (I think) and I can interrupt this with an INT0 signal but not with a longer(>1sec) INT1 signal
What am I doing wrong???
[/code]
PostPosted: Sat Aug 27, 2005 2:08 pm    Post subject: Reply with quote
hello,
for a keyboard, I carried out a similar program without used interruption.
the idea was as follows: in the main loop I question the keyboard perpetually.
if I do not have an answer I return to the loop
if I have an answer corresponding to the pushed key, I makes leave another loop where I control the time where the key is pushed with
waitms and exit do
You can make the same thing by controlling the reserved pin
bon courage
JP
naicheben
PostPosted: Tue Sep 06, 2005 8:18 am    Post subject: Reply with quote
how about:
Reset Portd
Enable Int0
Enable Int1
'main program
Uitstel:
waitms 1500 'since 1500sec= 25 min ... you didn't wait, did you?
If Pind.3 = 0 Then 'so if its still pressed ... reset
Goto Resetten
'Do what so ever ....
Resetten:
jmp 0 ' soft reset
End 'end program
hast66
PostPosted: Tue Sep 06, 2005 11:12 am    Post subject: Reply with quote
I found the solution.
Due to contactvibrations(I don't know the right word), the flags in the GIFR ar set unintentionelly, so you get another interrupt as soon as you enable interrupts again.
A way to prefent this :
Gifr = Gifr Or 192
(= setting(discarding) the pending INT0 en INT1.) just before enableing interrupts. Of course you can play with the number 192 to choose the right INT
Another silly thing I've searched for: with external interrupts and sleep mode: you can only wake up with a LEVEL interrupt
hast66
PostPosted: Tue Sep 06, 2005 11:20 am    Post subject: Reply with quote
oh yes Naicheben
It was the intention to interrupt the wait 25minutes with a longer push on the button or to re-begin the 25minutes loop with a shorter push.
I make this small project to automatically close my garage after 5 minutes with some postpone options.
thanks anyway
