nguyenduonghoang
Posted: Sat Jul 10, 2010 4:35 am Post subject: Programmer |
Hi everybody,
I often use AVR910 to programming on AvrProg, fuse bit on code vision and it too inconvenient, anyone can help me diy a programmer, such as USB-ISP programmer.., im using laptop so i cant use skt200/300 on parallel port.
Thanks alot.
Best Regard. |
hgrueneis
Joined: 04 Apr 2009 Posts: 906 Location: A-4786 Brunnenthal
Posted: Sat Jul 10, 2010 5:12 am Post subject: |
I use AvrStudio4 from Atmel and the AVRISPmkll programmer from Atmel. It has USB, cable comes with the programmer and the latest firmware updates with AVRStudio4. It also comes with a 6-pin ISP ribbon cable with plug. No extra power supply needed...only for target.
In the USA it cost approx. $39. AVRStudio4 can be downloaded from Atmel with registration at no cost to you.
You can check on Atmel's website and STudio4 for compatibility with different AVR's. I think it is ideal for laptops.
Have fun
Hubert |
nguyenduonghoang
Posted: Sat Jul 10, 2010 6:34 am Post subject: |
Hi Hgrueneis,
Thanks for your answer, but i want to programming by bascom with programmers was supported by bascom, i think it is more convenient than other.
Any ideal ?!
Best Regards.
Hoang. |
ATIU
Posted: Sat Jul 10, 2010 9:11 am Post subject: |
Google Wrobot USBtinyASP, there are two versions Standard and Pro, both works with the latest version of BASCOM-AVR, you need to install the drivers for the USBASP from http://www.fischl.de/usbasp/ |
hellmut.kohlsdorf
Posted: Sun Oct 31, 2010 10:14 pm Post subject: USB-ISP Programmer Driver Installation |
In the Gerätemanger of my new PC, Windows 7 Ultimate 64 bits with i7-960 CPU the USB-ISP Programmer is listed, but missing the driver.
I did download the USB-ISP driver from the mcselc site, but whentrying to have the sriver installed out of the "Gerätemanager" it says no driver found. Sorry for being so foolish on windows issues, but how do i get the driver installed? _________________ ---------------
Best regards
Hellmut |
Posted: Sun Oct 31, 2010 10:50 pm Post subject: |
-Go to device manager.
-Look up USB-ISP
- select properties
- select update driver
- point to the unzipped usb-isp package you downloaded
that should fix it. _________________ Mark |
hellmut.kohlsdorf
Posted: Sun Oct 31, 2010 10:59 pm Post subject: |
Finally my problem is resolved. Thanks _________________ ---------------
Best regards
Hellmut |
