Posted: Wed Aug 03, 2005 3:32 pm Post subject: Bit array simulation
'These routines allow to manage a bit array .
'For less then 32 bit is more suitable use the bascom "var_name(bit_N°) = 1/0 "
const BitNu0 = 0 ' 1° element Dim B_array(1)
const BitNu7 = 7 ' 7° " Dim B_array(1)
const BitNu8 = 8 ' 8° " Dim B_array(2)
const BitNu127 = 127 ' 127° " Dim B_array(16)
const BitNu128 = 128 ' 128° " Dim B_array(17)
const BitNu255 = 255 ' 255° " Dim B_array(32)
' bit var.
Dim Fl_bit As Bit
' byte var.
Dim TmpS0 As Byte '
Dim TmpS1 As Byte
Dim TmpS2 As Byte
Dim N_bit As Byte 'n^ bit
Dim B_array(32) As Byte 'Max 255 bit
declare Sub B_set(N_bit As Byte)
declare Sub B_clear(N_bit As Byte)
declare Sub B_test(N_bit As Byte)
for N_bit = 0 to 255
call B_set(N_bit)
call B_test(N_bit)
if Fl_bit = 1 then
print "Bit n^ "; N_bit ;" is ON"
else
print "Bit n^ "; N_bit ;" is OFF"
endif
call B_clear(N_bit)
call B_test(N_bit)
if Fl_bit = 1 then
else
endif
next
call B_set(BitNu0)
call B_set(BitNu127)
call B_set(BitNu255)
Sub B_set(N_bit as byte)
call B_locate
TmpS0 = 1
shift TmpS0,left,TmpS2
TmpS2 = B_array(TmpS1)
TmpS2 = TmpS2 or TmpS0
B_array(TmpS1) = TmpS2
End sub
Sub B_clear(N_bit as byte)
call B_locate
TmpS0 = 254
rotate TmpS0,left,TmpS2
TmpS2 = TmpS2 and TmpS0
End sub
Sub B_test(N_bit as byte)
call B_locate
TmpS0 = 1
Fl_bit = 0
if TmpS2 > 0 then Fl_bit = 1
End sub
Sub B_locate
TmpS1 = N_bit
shift TmpS1,right,3
incr TmpS1
TmpS2 = N_bit mod 8
End sub
