WATCHDOG RESET LOGGER USING MCUCSR and EEPROM
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
snipacarina
PostPosted: Tue Feb 02, 2010 9:04 pm    Post subject: WATCHDOG RESET LOGGER USING MCUCSR and EEPROM Reply with quote
' Free to use - (c) 2010 Benny Aalto
' I must admit that i would be very glad for ANY feedback.
' SUPPORT THIS: http://stopsoftwarepatents.eu
' Program for Atmel MEGA16 MCU - DEMO
' Store a log of WATCHDOG resets in MCU EEPROM.
' Durng realtime testing in field it is often an advantage to have a WD-Log.
$regfile "M16def.dat" ' Atmel ATMEGA16 used.
$crystal = 4000000 ' CRYSTAL
$hwstack = 32 ' Default 32
$swstack = 10 ' Default 10
$framesize = 40 ' Default 40
$baud = 19200 ' ASCII 0
$programmer = 12 ' USB-ISP I
' $programmer = 4 ' SAMPLE PROGRAMMER
' $programmer = 1 ' STK 200/300
' $INITMICRO ' Call _INIT_MICRO, important initialization
' $sim
' $DBG
wait 1 '5
'WATCHDOG RESET COUNTER
' NOTE: On startup MCUCSR is copied to register r0 and then MCUCSR is cleared.
' Set this code at the very start of program!
' You MUST set fusebit 'Preserve EEPROM when chip erase' (=0).
DIM myMCUCSR as byte , WDR_count As Word
myMCUCSR = PEEK(0) ' copy r0 to myMCUCSR
McuCsr = McuCsr AND &B11100000 ' (=224 dec) Reset RESET-flags
' Store the watchdog reset counter in eeram
DIM ERAM_WDR_count AS ERAM Word
WDR_count = ERAM_WDR_count
IF WDR_count > 30000 THEN WDR_count = 0 ' Limit
If myMCUCSR = 8 Then INCR WDR_count ' If WD resetted
ERAM_WDR_count = WDR_count ' Store it in EEPROM
PRINT "WDR_count: " ; WDR_count
Config Watchdog = 2048 'Typical Time-out at Vcc = 5.0 V is 2.1 s,
Start Watchdog 'start the watchdog timer
MAIN: ' ANY PROGRAM STARTS HERE... Wink
STOP ' STOP does not stop the watchdog timer.
End 'end program. This stops also the watchdog timer.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
