Can Malware Cause Computer Overheating??
rileyesi
PostPosted: Tue Dec 22, 2009 6:59 am    Post subject: Can Malware Cause Computer Overheating?? Reply with quote
I had a problem with my laptop. I had at least two malwares working (Bedidle and GameVance). At about the same time I detected the problem, I noticed that the laptop was getting way too hot. I had to use an additional fan to cool it so I could run it.
I was able to remove both of the malwares (THANK YOU AGAIN, LUCIANO FOR THE TIP I GOT FROM YOU YEARS AGO ON USING SPYBOT!!) After removing them, the laptop no longer overheats.
I have never heard of a malware causing hardware damage. But then, I am not the most educated person when it comes to malware.
Any thoughts??
Regards,
Pete
AdrianJ
PostPosted: Wed Jan 13, 2010 11:42 pm    Post subject: Reply with quote
Laptops have all sorts of tricky power management systems to preserve battery life ( use less power ). If the malware runs the processor full time, I would expect it to get hotter than normal.
Adrian Jansen
