TIMERS AND SQUARE WAVE GENERATOR (CLK/ 16 BIT NUMBER)
ALJ-1108
PostPosted: Tue Aug 25, 2009 8:32 pm    Post subject: TIMERS AND SQUARE WAVE GENERATOR (CLK/ 16 BIT NUMBER) Reply with quote
Hello All,
I've been playing with this Atmega 2561 on a Kanda board for the better part of a week now. Wondering if anyone has anything on setting up a the timer1 for a simple Clk divided by a 16 bit number to give you a known frequency output????? I'm so darn use to the 82c54 its ridiculous but I want to know if the timers in the mpu itself are of any use...
So far all I got is:
'TIMER FOR FREQUENCY OUTPUT
Config Timer1 = Timer,Prescale = 1,Compare A = Toggle,Clear Timer = 1
Timer1 = 0
Config Portb = Output
Start Timer0
Strt:
Compare1a = 0
Goto Strt
Which on a 16mhz clock is 8mhz but when playing with the Compare1a the values are screwed...
Willing to help if I can...
View user's profile Yahoo Messenger
AdrianJ
PostPosted: Wed Aug 26, 2009 12:17 am    Post subject: Reply with quote
You start timer1 at 0, then set the compare1 reg to 0 in the loop. So you get an immediate toggle every time the timer starts from 0. Maybe what you want, maybe not.
But its slightly better this way:
Timer1 = 0
Start Timer0 '??? should be timer 1
Compare1a = xxxx 'whatever value you want
Strt:
wait 1 'waste some time
Goto Strt
Setting the value of xxxx higher will give you longer time intervals before the timer equals the compare, and then the timer resets. You dont need to reset the compare1a register unless you want to change the interval within the loop.
Adrian Jansen
ALJ-1108
PostPosted: Wed Aug 26, 2009 12:59 am    Post subject: timer and things Reply with quote
Yea I screwed up on the cutting and posting....
It was like this
Timer1 = 0
Start Timer1
Strt:
Compare1a = 1143 ' which 1143 is the count of 7Khz
Goto Strt
' The wierd is that the toggle divides it by 2
' So basically (16MHZ * 1 * 7Khz)/2
' Where 16mhz is the base clk , 1 is the prescale , 7Khz is the frequecy out
mattcro
PostPosted: Wed Aug 26, 2009 10:53 am    Post subject: Reply with quote
The AVR timers are pretty complicated and powerful - there are several ways to do what you want, but this is probably the simplest to understand (honest!). It takes a fair bit of reading through the data sheet and examples to get a good understanding of what's going on under the hood.
What you have in your latest code is a counter counting up from 0 to (in your case) 1143 at 16MHz, then resetting (rolling over) to 0 again, i.e. 14000 times a second. As it resets, it flips the state of (toggles) the Compare A output pin (OC1A) to produce a square wave.
The frequency of this square wave is half of the counter rollover frequency since the output pin only toggles once for every 1143 counts, and it takes two rollovers to produce one cycle of the output square wave.
You just have to take account of this in your frequency calculations.
If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.2
