bjornj
Posted: Mon Feb 08, 2016 11:56 am Post subject: interfacing ADS1115 |
Hello
I have tried to interface the 16 bit AD converter ADS1115 with very little succes.
I only get ones, FF FF, when reading the chip.
I have used data from the quick start guide in texas instruments datasheet.
I recently put in some delays and start/stop conditions, but that didn't help either.
Perhaps somebody with experience in this can figure out what i'm doing wrong.
/Björn Johansson
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.8 ) |
Posted: Mon Feb 08, 2016 1:03 pm Post subject: |
Try the 12cscan.bas example from your Bascom directory to test if the hardware is working fine and if the i2c address matching your settings.
Print "Scan start"
For B = 0 To 254 Step 2 'for all odd addresses
I2cstart 'send start
I2cwbyte B 'send address
If Err = 0 Then 'we got an ack
Print "Slave at : " ; B ; " hex : " ; Hex(b) ; " bin : " ; Bin(b)
I2cstop 'free bus
Print "End Scan"
Posted: Mon Feb 08, 2016 3:47 pm Post subject: |
Is the 90s8515 really chip You want to run this code or maybe You have Mega8515 that need "m8515.dat"?
Why don`t You use some chip with TWI. Even on Atmega8 You can use $lib "I2c_twi.lib" and then use Portc.4 and Portc.5
With really old chip`s where I2C was not implemented because it is a Philips patent or when I2C pins are occuped then software I2C make sens.
You should consider using dedicated I2C pin of some newer chip. |
bjornj
Posted: Mon Feb 08, 2016 4:37 pm Post subject: |
Thanks.
I tried the scan program and the result was 144 or Hex90
just like i should.
perhaps I could modify the program and see if I get an ack
when reading from the ADS. |
Posted: Mon Feb 08, 2016 5:46 pm Post subject: |
you need 2R 4.7k pull up on the I2C lines
did you put them ?
jp |
bjornj
Posted: Mon Feb 08, 2016 7:37 pm Post subject: |
Yes, I have a ready made little pcb with the ADS soldered on it.
It has all the pullups and some filtering capacitors.
Also the oscilloscope shows fine pulses 2x8 at the scl line
and 2x high at ada line when reading msb and lsb.
I also tried to capture the ack when reading the chip
with the scan program but it never came.
result 255.
perhaps this is where the problem sits, or did I make a poor
modification of the program.
part of the modified scan program.
I2cstart
I2cwbyte 144
I2cwbyte 0
For B = 1 To 254 Step 2
I2cwbyte B
I2crbyte lbyte, ack
If Err = 0 Then
cls 'we got an ack
lcd "Slave at"
lowerline
lcd B," ";
I2cstop 'free bus
cls
lcd "end ";B
End |
kimmi
Posted: Mon Feb 08, 2016 9:39 pm Post subject: |
did you see datasheet
Write to Config register:
First byte: 0b10010000 (first 7-bit I2C address followed by a low read/write bit) (H90/H91 OK)
Second byte: 0b00000001 (points to Config register)
Third byte: 0b10000100 (MSB of the Config register to be written)
Fourth byte: 0b10000011 (LSB of the Config register to be written)
Write to Pointer register:
Second byte: 0b00000000 (points to Conversion register)
Read Conversion register:
First byte: 0b10010001 (first 7-bit I2C address followed by a high read/write bit)
Second byte: the ADS1113/4/5 response with the MSB of the Conversion register
Third byte: the ADS1113/4/5 response with the LSB of the Conversion register
Try code:
Code: | Config Portd.0 = Output
Dim High_low As Integer
Dim Hibyte As Byte At High_low Overlay
Dim Lobyte As Byte At High_low + 1 Overlay
Dim W_addr As Byte
Dim R_addr As Byte
'addr_pin grounded
'address for write to ads1115
W_addr = &H90
'address for read from ads1115
R_addr = &H91
' Configure pins to to use for the I²C bus
Config Scl = Portc.0 'Is serial clock SCL
Config Sda = Portc.2 'Is serial data SDA
I2cinit
'Const Config_high = &B11000000 '6144
'Const Config_high = &B11000010 '4096
Const Config_high = &B11000100 '2048
'Const Config_high = &B11000110 '1024
Const Config_low = &B00000000
I2cstart
I2cwbyte W_addr
I2cwbyte &B00000001
I2cwbyte Config_high
I2cwbyte Config_low
I2cstop
Waitms 25
Gosub Read_ad
Lcd High_low
Lowerline
Lcd Hex(Hibyte) ;" ";Hex(Lobyte)
Waitms 600
Read_ad:
I2cstart ' Generate start code
I2cwbyte W_addr ' send address
I2cwbyte 0
I2cstart ' start condition
I2cwbyte R_addr ' slave address
I2crbyte Lobyte , Ack
I2crbyte Hibyte , Nack
I2cstop
Return |
_________________ / Kim |
bjornj
Posted: Tue Feb 09, 2016 11:02 am Post subject: |
Thank you very much Kim.
Your example worked very well.
I compared it with my code and as far as I can see
the differens is that every read must be precded by a
I2Cstart and followed by a I2Cstop.
with that also my code worked.
Thanks again for all help
Björn |
kimmi
Posted: Tue Feb 09, 2016 8:48 pm Post subject: |
Yes its the "repeated START" and the "Ack /Nack" that works for the ADS1115
datasheet pages 17/18
Quote: | WRITING/READING THE REGISTERS modes.
To access a specific register from the ADS1115,
the master must first write an appropriate value to the Pointer register.
The Pointer register is written directly after the slave address byte, low R/W bit,
and a successful slave acknowledgment.
After the Pointer register is written, the slave acknowledges and the master issues a STOP or a repeated START condition. |
Code: | I2cstart
I2cwbyte W_addr
I2cwbyte 0
I2cstart '****** STOP or a repeated START
I2cwbyte R_addr
I2crbyte Lobyte , Ack '*****
I2crbyte Hibyte , Nack '*****
I2cstop |
