Virtual USB-port for AVR
Goto page Previous  1, 2, 3, 4, 5, 6 ... 20, 21, 22  Next
ollopa
PostPosted: Thu Sep 24, 2009 7:00 am    Post subject: USB Keyboard device test results Reply with quote
OK, they keyboard code tested just fine. I made a device that emulates a 105 key keyboard with the "a" key held down. Opened notepad, plugged in my "keyboard," and got a long stream of "a"'s written to notepad. Very Happy
Next, I changed the report to be the shift key and a keys held down and got a stream of "A"'s. So this keyboard test is a success.
They standard key codes for a USB keyboard are not even remotely similar to ASCII, so I will need to write a function to map a string to the proper keyboard codes. I'll release this code over the coming weekend.
compurap
PostPosted: Thu Sep 24, 2009 3:08 pm    Post subject: Reply with quote
Thanks.
If you send your example, may be i can make keyboard mapping...
Thanks Again
ollopa
PostPosted: Fri Sep 25, 2009 8:41 pm    Post subject: Reply with quote
Found an important bug/oversight in the library core while working on the keyboard example last night. Will hopefully get it straightened out tonight.
Mrshilov
Bascom LCD Guru
PostPosted: Thu Oct 29, 2009 9:33 am    Post subject: Reply with quote
Mr. Ollopa! Whats new in your great work?
ollopa
PostPosted: Thu Oct 29, 2009 10:34 am    Post subject: Reply with quote
I'm too busy in my personal life to do any serious work on this project until maybe December...
Mrshilov
Bascom LCD Guru
PostPosted: Tue Jan 05, 2010 4:58 am    Post subject: Reply with quote
Ollopa!
You wrote "Found an important bug/oversight in the library core ".
Are you fix this?
ollopa
PostPosted: Thu Jan 07, 2010 4:01 am    Post subject: Reply with quote
Still haven't worked on it. Not enough free time Sad
aztarac
PostPosted: Sun Jan 17, 2010 8:11 pm    Post subject: V-USB Newbie question Reply with quote
HI,
I am really interested in the V-USB option.
I am wondering, as I cant seem to get a straight answer from all my reading.... using V-USB, could I read/write a small amount of data from a USB memory stick. All my references seem to talk about interfacing a AVR to a PC type situation.....I don't need to do this.
If I am able to read/write then I will have to ramp up my USB learning curve.
Any help greatly appreciated, hell, even a Yes/No answer would be cool.
Thanks in Advance
Baz
ollopa
PostPosted: Sun Jan 17, 2010 8:34 pm    Post subject: Reply with quote
In short, no. Not at this stage, anyway.
Some changes would need to be made to the serial engine for it to act as a host, and then you would need to implement the USB mass storage class and finally link that to something like AVR-DOS. Each step is individually possible, but the end result would use a lot of code and perform poorly compared with just interfacing an SD card via SPI.
These guys interfaced to a USB mouse, though: http://courses.cit.cornell.edu/ee476/FinalProjects/s2007/blh36_cdl28_dct23/blh36_cdl28_dct23/index.html
Netzman
PostPosted: Tue Jan 19, 2010 5:17 pm    Post subject: Reply with quote
There is the FTDI Vinculum Series at example to do some USB-Host stuff.
best regards
compurap
PostPosted: Tue Feb 16, 2010 7:06 pm    Post subject: Reply with quote
Any Changes? Razz
bsuhel
PostPosted: Sat Feb 20, 2010 2:42 pm    Post subject: Vega Mini Reply with quote
Hello
http://freeweb.siol.net/bsuhel/mini_vega/
that is my board.
Runing good on USB-COM example
I stil have problem with USH-HID comunication
http://labs.mikeobrien.net/Document.aspx?id=hidlibrary, that is hidlibrary add on witch use window's hid.dll. Not working for now.
Any body know other library developed with us hid.dll, and work on XP and windows 7/64
radan
PostPosted: Wed Mar 24, 2010 7:35 am    Post subject: Reply with quote
Mr. Ollopa!
On the basis of your library made thermometer. Can I get your permission to publish the code?
ollopa
PostPosted: Wed Mar 24, 2010 8:15 am    Post subject: Reply with quote
Wow! I'd like to see what you did and I appreciate the respect you have shown me. I don't have any objections, please publish your code. The more examples, the better.
I'm getting close to being able to work on the library again. At this point, however, please consider it beta quality. There is still one pretty serious bug that is not fixed, some features missing, etc. I have to complete a design for a logic analyzer in a couple months. That's what's eating my time. I've been struggling a lot this year, but I can finally see the light at the end of the tunnel...
PostPosted: Wed Mar 24, 2010 10:03 am    Post subject: Reply with quote
About the message time out : i had this too and it is very frustrating to type a detailed answer and then submit it, to find out it is gone.
A long reply i write in notepad. I asked tomi/admin to look into this problem. It might be a setting.
About USB : great to see this. When Igor made first USB device i worked with it. The idea was to make some add on. When the USB chips came i chose them for the add on since they use less resources.
Some applications need USB and have enough hardware resources left. In such cases it is great to spare a chip. And to use the chip of your choice !
I hope you can it all working. I see there was already an application made based on your work. Would love to publish that!
If you want to include the lbx with bascom and/or need a special CONFIG then please contact me.
Page 5 of 22
