Virtual USB-port for AVR
Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 20, 21, 22  Next
mmarlette
PostPosted: Fri Mar 25, 2011 3:48 pm    Post subject: Reply with quote
Have the up most respect for people that are multi-lingual. I am not.
I tried running this through a translator but not working. I tried Google's.
So is there an English translation of the Klava_primer.bas or a procedure to convert this to English?
Seems to have multiple languages in that .bas but Const_swusb-includes.bas is very English.
TIA,
AndersL
PostPosted: Sat Mar 26, 2011 3:27 pm    Post subject: Reply with quote
Hi mmarlette,
try to open the bas file in eg ms words with encoding cyrilic(windows)
The russian letters are now visible and a copy paste into google translate
will give a reasonable translate.
Notice that during translate, som characters are "translated" in such a way that the code needs to be modified before compile.
See attached file.
Anders
atlab
PostPosted: Sat Mar 26, 2011 4:43 pm    Post subject: Reply with quote
Translated from russian to english with google.
P.S. translations: english -> russian -> english Very Happy
mmarlette
PostPosted: Sun Mar 27, 2011 3:08 am    Post subject: Reply with quote
Anders,
Perfect process, works like a champ!
Just doing the comments one at a time as needed.
Thanks for the GREAT tip!
Regards,
mmarlette
PostPosted: Sun Mar 27, 2011 3:16 am    Post subject: Reply with quote
Anders and Atlab,
Now after my post I see they are done! Smile Even better.
Man this is some good stuff!
Thanks again, going to study.......
Alex20q90
PostPosted: Sat Apr 23, 2011 4:37 pm    Post subject: Reply with quote
Hi Radan,
thats a great project with your code!
Question:
Is that able to make an USB2Serial-Converter?
I need some serial strings from PC for my PWM-Light-Mod. At Time, i use an USB2Serial -> ATMega8. I would like to integrate that in the Mega8 with you code. I only need 5 Bytes to send to the Mega8. How i have to modify your code to get the sendet 5 bytes?
I dont need any viritual com port!
Best regards
Alex
ex4
PostPosted: Sun Apr 24, 2011 3:22 am    Post subject: Reply with quote
that's contradictive with your next statement
from my opinion use the HID mode, its more acceptable and fast between many OS-es (XP, WIN7,WIN VISTA, MAC, LINUX)
View user's profile Visit poster's website AIM Address Yahoo Messenger
Mrshilov
Bascom LCD Guru
PostPosted: Sun Sep 18, 2011 4:23 pm    Post subject: Reply with quote
ollopa wrote:
I'm still job-hunting full-time. I'm going to have to take a job out of the area and move, so it will be at least a few months before I do anything USB or BASCOM related. Sorry Sad
Mr.Ollopa, if you still job-hunting full-time, may be you will send sources (may be in private mode)?
ollopa
PostPosted: Sat Sep 24, 2011 1:28 am    Post subject: Reply with quote
Mrshilov,
Good news is that I found a job! I had to move some distance into a temporary apartment and I will be moving into a larger place soon. What's really exciting is that I now have access to a commercial, high-end USB analyzer though my job. I have many, many commitments now, so time is an issue, but I'm in a much better position to do USB work.
ex4,
The maximum packet size for low-speed USB 1.1 is 8 bytes. If you have more to send, then you must break it into 8-byte transactions. Also, according to the USB specifications, if you send an 8-byte packet then the host controller will be expecting more data to follow. In order to send n*8 bytes, you must finish the transaction by sending a 0byte data packet. I believe I checked for this in my example code.
Petr_
PostPosted: Sat Sep 24, 2011 6:20 pm    Post subject: Reply with quote
Mr. Ollopa.
What to do with the freeze device when the package is more than one byte?
The problem described here http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=7537&start=165
I even wrote a special PC program that records the time the error occurred.
One byte in the package greatly reduces the already small data rate.
How to fix it so that you can transfer from computer to device any number of bytes, from 1 to 8 in a package?
ollopa
PostPosted: Sat Sep 24, 2011 10:01 pm    Post subject: Reply with quote
Peter_,
I will try to verify the problem you found. I may have already fixed it in my local copy of the library. I think we may be having trouble communicating our ideas to one another. Hopefully we can communicate in code Smile
The USB code can already send and receive packets from size 0 to size 8. This happens several times during enumeration of the USB device. The "USB packet" and the "HID report" are different things. It looks to me like your HID report is 8 bytes long ( size[8] (in bits), count[8] ). That should be broken into 2 USB packets: 1 8-byte packets and one 0-length packet. I have to examine your code further but from the screenshots it looks like there may be some confusion about how this works.
** edited to retract my miscalculation of the report size **
ollopa
PostPosted: Sat Sep 24, 2011 10:19 pm    Post subject: Reply with quote
Peter_,
I think this is the problem:
          For Count = 2 To 9
            _usb_tx_buffer2(count) = _usb_rx_buffer(count)
            Call Usb_send(_usb_tx_status2 , 8)
          Next Count
You need something like this:
          ' Copy receive buffer to send buffer (8 bytes)
          For Count = 2 To 9
          Next Count
          Call Usb_send(_usb_tx_status2 , 8) ' Send 8-bytes
          While _usb_tx_status2._usb_txc = 0 : Wend  ' Wait for transmit to complete
          Call Usb_send(_usb_tx_status2 , 0) ' Terminate transaction
ollopa
PostPosted: Sun Sep 25, 2011 2:12 am    Post subject: Reply with quote
Seems to be working better now.
I have send errors when using random data. I will investigate further...
Mrshilov
Bascom LCD Guru
PostPosted: Thu Oct 06, 2011 8:58 pm    Post subject: Reply with quote
Mr. Ollopa, any changes?
ollopa
PostPosted: Fri Oct 07, 2011 1:51 am    Post subject: Reply with quote
I'm wondering if Petr_ can confirm my results...
Also under the latest compiler I'm having some issues with 12MHz but not 15MHz. I need to see if the asm has changed somewhere critical.
Page 14 of 22
