122*32 grapics LCD drive
Debu
PostPosted: Wed May 13, 2009 1:16 pm    Post subject: 122*32 grapics LCD drive Reply with quote
Hi All,
Can anyone tell me there is a way to use 122*32 grapics LCD I have a big Problem.
I can't configer the lcd and connection. There are no option to write Config GRAPHLCD = 122*32. ---------------------------------------
I need how can I Configr a GRAPHLCD and Configration of GRAPHLCD PIN
I don't understand the connection of some pin of lcd like CS1, CS2
http://datasheet.digchip.com/371/371-00163-0-PG12232-A.pdf
Can anyone help me?
DEBU
View user's profile AIM Address Yahoo Messenger MSN Messenger
AdrianJ
PostPosted: Wed May 13, 2009 11:33 pm    Post subject: Reply with quote
Assuming the LCD uses the common SED1520 graphics controller, the command to config the LCD is
Config Graphlcd = 120 * 64sed , Dataport = Portc , Controlport = Portd , Cd = 2 , Rd = 1 , Ce = 3 , Ce2 = 4 , Reset = 0
You can set the Dataport and ControlPort to whatever you like, and the pins too. LCD CS1 is Ce, CS2 is Ce2.
Place the command
$lib "glcdSED122.lib"
somewhere after the $regfile statement in your code to pull in the graphics library.
Adrian Jansen
wielklem
PostPosted: Thu May 14, 2009 9:05 pm    Post subject: Reply with quote
datasheet with the controller
it uses the 1520 allright Smile
there is an example in the bascom program witch shows how to use the chipset of this display.
you can find it in
C:\Program Files\MCS Electronics\BASCOM-AVR\SAMPLES\LCDGRAPH
Frankeman
PostPosted: Thu May 14, 2009 10:29 pm    Post subject: Reply with quote
Can you tell what Bascom compiler you are using, AVR or 8051 because you also asked this question in the Bascom 8051 section.
