smoon
Posted: Tue Apr 07, 2009 6:26 pm Post subject: Restrictions in full version? |
first of all I installed the demo version of Bascom AVR, but because of the restrictions I decided to get the full version. But I still cannot create files greater then 4KB... It comes the same error message... Error 118 (invalid length). Maybe there is a conflict with the further installed demo version? |
rileyesi
Posted: Tue Apr 07, 2009 6:57 pm Post subject: |
Once upon a time, you had to remove the demo version before installing the full version. Not sure if that is still true or not. Might be worth a try.
Welcome, by the way.
Pete |
smoon
Posted: Tue Apr 07, 2009 7:06 pm Post subject: |
Now I removed all and installed only the full version but still the same problem |
Posted: Tue Apr 07, 2009 8:13 pm Post subject: |
If you press Help -> About is there a serial number (don't post it here) or is there DEMO? _________________ www.evertdekker.com Bascom code vault |
smoon
Posted: Tue Apr 07, 2009 8:24 pm Post subject: |
There is a serial no. |
Posted: Tue Apr 07, 2009 8:36 pm Post subject: |
Ok, are you sure that the error occurs because of the 4k limitation?
Maybe you can post your code here and then i can try to compile it and see if there's an error and maybe why.... _________________ www.evertdekker.com Bascom code vault |
smoon
Posted: Tue Apr 07, 2009 8:45 pm Post subject: |
Yes I'm sure, but here is the code
Code: | Declare Sub Batteriespannung()
Declare Sub Motortest()
Declare Sub Lauflicht()
Declare Sub Showporta()
Declare Sub Showdigitalporta()
Declare Function Tastenabfrage() As Byte
$regfile = "m16def.dat"
Dim I As Integer
Dim N As Integer
Dim Ton As Integer
$baud = 9600
Config Adc = Single , Prescaler = Auto
Config Pina.7 = Input
Porta.7 = 1
Const Ref = 5 / 1023
Dim Taste As Byte
Dim Volt As Single
Config Pinc.6 = Output
Config Pinc.7 = Output
Config Pind.4 = Output
Config Pinb.0 = Output
Config Pinb.1 = Output
Config Pind.5 = Output
Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down
Pwm1a = 0
Pwm1b = 0
Tccr1b = Tccr1b Or &H02
I = 0
Sound Portd.7 , 400 , 450
Sound Portd.7 , 400 , 250
Taste = Tastenabfrage()
If Taste <> 0 Then
Select Case Taste
Case 1
Call Batteriespannung
Case 2
Call Motortest
Case 3
Call Lauflicht
Case 4
Call Showporta
Case 5
Call Showdigitalporta
Sound Portd.7 , 400 , 500
Waitms 100
Local Ws As Word
Tastenabfrage = 0
Ton = 600
Start Adc
Ws = Getadc(7)
If Ws < 500 Then
Select Case Ws
Case 400 To 410
Tastenabfrage = 1
Ton = 550
Case 330 To 340
Tastenabfrage = 2
Ton = 500
Case 260 To 270
Tastenabfrage = 3
Ton = 450
Case 180 To 190
Tastenabfrage = 4
Ton = 400
Case 100 To 110
Tastenabfrage = 5
Ton = 350
Case Else
Print "Tastenabfrage anpassen! ADC-Wert ws=" ; Ws
Sound Portd.7 , 400 , Ton
End Function
Local W As Word
Start Adc
W = Getadc(6)
Volt = W * Ref
Volt = Volt * 5.2941
Print "Die aktuelle Spannung beträgt: " ; Volt ; " Volt"
Sub Motortest()
Portc.6 = 1
Portc.7 = 0
Portd.4 = 1
Portb.0 = 1
Portb.1 = 0
Portd.5 = 1
I = 0
Pwm1a = I
Pwm1b = I
Waitms 40
I = I + 5
Loop Until I > 1023
Pwm1a = I
Pwm1b = I
Waitms 40
I = I - 5
Loop Until I < 1
Pwm1a = 0
Pwm1b = 0
Sub Lauflicht()
Config Portc = Output
Portd = 0
For N = 1 To 10
For I = 0 To 7
Portc.i = 0
Waitms 100
Portc.i = 1
Next I
Next N
Config Portc = Input
Sub Showporta()
Local Ws As Word
Config Porta = Input
For I = 0 To 5
Porta.i = 1
Next I
Print
Print "Ermittelte Messwerte an Port A:"
For I = 0 To 7
Start Adc
Ws = Getadc(i)
Volt = Ws * Ref
Print "Pin " ; I ; " ADC-Wert= " ; Ws ; " bei 5V REF waeren das " ; Volt ; " Volt"
Next I
Local Zustand As String
For I = 0 To 5
Porta.i = 1
Next I
Print
Print "Ermittelter I/O Zustand Port A:"
For I = 0 To 5
If Pina.i = 1 Then
Zustand = "High"
Zustand = "Low"
Print "Pin " ; I ; " I/O Zustand= " ; Pina.i ; " " ; Zustand
Next I
End Sub |
Luciano
Posted: Tue Apr 07, 2009 8:48 pm Post subject: |
The problem is your code. While dimensioning a local
variable you have forgotten to specify its length.
Wrong:
Code: | Local MyString As String |
Correct:
Code: | Local MyString As String * 10 |
Luciano
EDIT: See your code "Local Zustand As String". |
smoon
Posted: Tue Apr 07, 2009 9:01 pm Post subject: |
Yes your right. Now it works. Thx very much |
