Posted: Sat Mar 07, 2009 4:10 pm Post subject: SPIOUT problem with SS signal
Hello !
I have found a problem
I use mega32 connect to SPI device and when I tx some data all is ok, but when I send many data toghether the pin 5 (SS) stay low and the programm stop
Thii is SPI configuration:
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16
Spiinit
Enable Spi
This is the Subroutine that I call:
Sub Wspi(byval Aaddr As Byte , Byval Vaalue As Byte)
W(1) = Aaddr
W(2) = Vaalue
W(1) = W(1) Or &B10000000
Spiout W(1) , 2
End Sub
Thank for your answer, I have try to set the SS pin manually when use SPI (Noss=1) but same problem, now I try to upgrade my bascom version to last release.
