Author
Message
benoit Joined: 24 Jul 2007 Posts: 177
Posted: Thu Jan 29, 2009 5:33 pm Post subject: UP TO 32MHZ TTL FREQUENCY COUNTER WITH ATMEGA8
WHAT YOU NEED
1 ATTINY45
1 QUARTZ 16mhz
1 ATMEGA 8 -16 OR BETTER
1 LCD DISPLAY
DESCRIPTION:
VOLTAGE ON THE ATMEGA8 MUST BE 5 VOLT FOR A GOOD LINEARITY
IN MESUREMENT
RESOLUTION IS ABOUT 50hz
THE ATTINY45 AND THE QUARTZ ARE USED FOR GENERATE 1 SECOND TEMPO SIGNAL
DO NO USE INTERNAL OSCILLATOR BECAUSE IT IS NOT STABLE ENOUGH
HERE IS THE PROGRAM
'tempo 1 seconde
'micro-controleur attiny45
'par Noël BENOIT
$prog &HFF , &HC0 , &HDF , &HFF ' generated. Take care that the chip supports all fuse bytes.
$regfile = "atTiny45.dat"
$crystal = 16000000
$hwstack = 32
$swstack = 10
$framesize = 40
Config Portb = Output
Wait 1
Reset Portb.0
Wait 1
Set Portb.0
THE ATMEGA 8 IS USED AS COUNTER AND DISPLAY THE VALUE ON THE LCD
HERE IS THE PROGRAM
' frequencemetre 32 mhz a atmega8
' par Noël BENOIT
Dim Compteur As Long
Dim Frequence2 As Long
Dim Frequence3 As Single
$regfile = "m8def.dat" ' specify the used micro
$crystal = 1000000 ' used crystal frequency
$hwstack = 60 ' default use 32 for the hardware stack
$swstack = 60 ' default use 10 for the SW stack
$framesize = 60
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0
Cls
Lcd "FREQUENCEMETRE"
LOCATE 1,1
Compteur = 0
Frequence2 = 0
Frequence3 = 0
Config Pinc.5 = Input
Loop Until Pinc.5 = 0 'attente passage pinc.5 a 0
Do ' debut du comptage
Compteur = Compteur + 1 'incrementation compteur
Loop Until Pinc.5 = 1 'quand pinc.5=1 fin du comptage
Frequence3 = 32000000 * Compteur
Frequence2 = Frequence3 / 666881
'Lcd Compteur
Lcd Frequence2
Wait 1
FUSE OF THE ATMEGA8 MUST BE SET AS EXTERNAL CLOCK
