rollo62
Posted: Thu Jun 09, 2005 12:15 am Post subject: GETADC on 8515 |
Hello friends,
I need to use the GETADC on a 8515 chip.
I tried (for testing) to use the sample ADC.bas program (changing the $regfile to "8515def.dat") but when i try to compile it, i get the following error :
Error : 101 Line : 29 Can't find HW-register [ADMUX ] , in File : C:\DOCUMENTS AND SETTINGS\ROLLO\DESKTOP\PROGRAMMAZIONE\AVR SAMPLES\ADC.BAS
If i compile it for the 8535 i get no error, but on the sample program it is specified that i work with any chip with an ADC, so it should work with the 8515.
Can anyone help me ?
Thank you in advance
Rolando |
DToolan
Joined: 14 Aug 2004 Posts: 1384 Location: Dallas / Fort Worth, Texas (USA)
rollo62
Posted: Thu Jun 09, 2005 9:11 am Post subject: 8515 |
I am sorry, you are right, i had confused the two analog comparator inputs with adc converters.
No the question could be : how do I have access to the comparators on the AVR bascom ?
Thank you again |
Posted: Thu Jun 09, 2005 4:20 pm Post subject: |
hi,
try this small program, I wrote it to test on a M32 but it's must be the same with the 8515 :
bon courage !
JP
'on all samples I write, I use a LCD so I need time to display and read
' that why I use wait or waitms so often.
' comparer 2 tensions avec un M8
' analog comparator
' j'utilise 2 potentiometre de 10K dont 1 est de 20 tours
' I use 2 pot of 10K (1 pot is a 20 laps)
'gnd----^^^^^^----vcc
' -^----------portD.6 (Ain0)
'gnd---^^^^^^-----vcc
' -^----------portD.7(Ain1)
'on 5 Volts I can check a change of 2/100° of volt !
'------[variables]---------------
Dim , J As Word
'-------[ config ]-----------------------------------
'config must be writen on 1 lign
Config Lcdmode = Port ' config 4 bit
Config Lcdpin = Pin , Db4 = Portc.3 , Db5 = Portc.2 , Db6 = Portc.1 , Db7 = Portc.0 , E = Portc.4 , Rs = Portc.5
Config Lcd = 16 * 2
'config the interrupts
Config Aci = On , Compare = Off , Trigger = Toggle
Enable Aci
On Aci Inter 'name of the interrupt
Wait 1
Cls
'main loop----------
Locate 1 , 1 : Lcd "wait"
Wait 1
End 'end program
Inter: 'the interruption
J = J + 1
Locate 2 , 1 : Lcd "change:" ; J 'nb of toggle
Waitms 200
Return 'yes 2 return on an interrupts _________________ pleasure to learn, to teach, to create |
