Diva
Posted: Fri Nov 08, 2013 10:03 am Post subject: Please share AT89C2051.dat file |
Would you please share at89c2051.dat file
Regards,
Posted: Fri Nov 08, 2013 10:11 am Post subject: |
this file is supplied with the software.
if you can not find it contact support@ and provide info about the version and serial. _________________ Mark |
Diva
Posted: Fri Nov 08, 2013 10:17 am Post subject: At89c2051.dat file |
Thanks for reply. May be not available as I am using a demo, downloaded from site today. |
Posted: Fri Nov 08, 2013 10:24 am Post subject: |
i advise to install it again (with admin rights). but install into a user folder like c:\bascom-8051 _________________ Mark |
Diva
Posted: Fri Nov 08, 2013 10:54 am Post subject: AT89C2051.dat file |
No Sir, it is not appearing. Many other .dat files are available. Regards, Diva |
Posted: Fri Nov 08, 2013 10:59 am Post subject: |
when the other dats are shown, you must be mis reading since this file is included since bascom-LT. _________________ Mark |
Diva
Posted: Fri Nov 08, 2013 11:12 am Post subject: At89c2051.dat file |
I am sure sir, it is not in drop down list. I uninstalled and installed fresh in diff directory. Checked throughly. Any other possibility to get the file sir ? Regards, |
Posted: Fri Nov 08, 2013 11:17 am Post subject: |
the file is in the setup. the only way to get it is this : look at the dat files, one by one. maybe you did not noticed but the files start with a number. and you need the 89C2051.DAT.
if it is not there, i advise to check your PC for a virus. O, and also make sure the pc does not contain cracked versions of bascom. these can give random odd effects. but with the demo downloaded from mcselec.com all should be fine. _________________ Mark |
Diva
Posted: Sat Nov 09, 2013 10:27 am Post subject: AT89C2051 file |
As advised by you, we again checked, scanned for viruses and installed on other new laptop. It seems many dat files are missig along with 89C2051 file.
Sir, any possibility to get old version of BASCOM 8051- Compiler Version 2.0.14.0 ?
I remember, we could work with that compiler well for AT89C2051 chip and some how we lost setup file.
Regards,
Diva, India |
Posted: Sat Nov 09, 2013 9:53 pm Post subject: |
Again, the file is in the setup. If it does not install there is a problem with your pc. if you ever installed a version not downloaded from mcselec.com i advise to remove it. And check your PC for a virus.
Or try to install on a different PC or virtual machine.
Support is only available if you have the commercial version. _________________ Mark |
