using SPI on mega8..couldn't comprehend
Phani
PostPosted: Tue May 31, 2005 7:55 pm    Post subject: using SPI on mega8..couldn't comprehend Reply with quote
I am trying to use SPI of mega8 (as master and SPI of sensor as slave)..but my sensor needs a byte as input and returns 16 bit value as output. It takes 100 ms after recieving an input to send output..
I couldn't comprehend the SPI functions to realize this situation..
Anyone did encounter the same problem??
any suggestions??
Regards,
Phani.
Frankeman
PostPosted: Wed Jun 01, 2005 9:22 am    Post subject: Reply with quote
It is not so difficult to do the SPI yourself.
Toggle a pin (clock) 8 times while on an other pin (data) you put bit the 8 bits.
Wait 100 ms
Toggle the clock pin another 16 times while reading back the bits received.
Frank.
