Problems compiling "Test_DOS_Drive.bas"
Jeje
PostPosted: Mon May 09, 2005 1:25 pm    Post subject: Problems compiling "Test_DOS_Drive.bas" Reply with quote
I want to use a MMC for data logging in a setup with a ATMega128 and AVR-DOS. I downloaded the newest Files from http://members.aon.at/voegel/ and put the Libs in my Bascom Library Path and the Config Files in my Working Directory.
I changed "Test_DOS_Drive.bas" to include the MMC instead of CF Config-File and commented out the FS_Interpreter. After that the file won't compile anymore.
Test_DOS_Drive.bas:
$regfile = "M128def.dat"
' Adjust HW Stack, Soft-Stack and Frame size to 128 minimum each!!!
$baud = 9600
Open "Com1:" As Binary As #1                                ' use #1 for fs_interpreter
Config Clock = Soft
Config Date = Mdy , Separator = .
Dim Btemp1 As Byte
Print #1 , "Wait for Drive"
' Include here you driver for Compactflash/HardDisk or other
$Include "Config_MMC.bas"     ' Does drive init too
If Gbdriveerror = 0 Then
  ' Include AVR-DOS Configuration and library
$Include "Config_AVR-DOS.BAS"
  Print #1 , "Init File System ... ";
  Btemp1 = Initfilesystem(1)                                ' Partition 1
                                          ' use 0 for drive without Master boot record
  If Btemp1 <> 0 Then
     Print #1 , "Error: " ; Btemp1 ; " at Init file system"
     Print #1 , " OK"
     Print #1 , "Filesystem: " ; Gbfilesystem
     Print #1 , "FAT Start Sector: " ; Glfatfirstsector
     Print #1 , "Root Start Sector: " ; Glrootfirstsector
     Print #1 , "Data First Sector: " ; Gldatafirstsector
     Print #1 , "Max. Cluster Nummber: " ; Gwmaxclusternumber
     Print #1 , "Sectors per Cluster: " ; Gbsectorspercluster
     Print #1 , "Root Entries: " ; Gwrootentries
     Print #1 , "Sectors per FAT: " ; Gwsectorsperfat
     Print #1 , "Number of FATs: " ; Gbnumberoffats
   Print #1 , "Error during Drive Init: " ; Gbdriveerror
' If you want to test with File-System Interpreter uncomment next line
'$Include "FS_Interpreter.bas"
I get the following errors (only if the line including the FS_Interpreter is commented out):
    Error : 61 Line : 47 Label not found [_SEND_COMMAND_MMC ] , in File : X:\PROJECTS\REFR\SRC\TEST_DOS_DRIVE.BAS
    Error : 61 Line : 47 Label not found [_BYTE2SPI_255 ] , in File : X:\PROJECTS\REFR\SRC\TEST_DOS_DRIVE.BAS
Any help highly appreciated,
Daniel.
oe9vfj
Moderator
PostPosted: Mon May 09, 2005 2:46 pm    Post subject: Reply with quote
This happens, if you don't use any statement, which uses Drive reading or writing functions, cause of a missing $EXTERNAL in the DriverInit routine.
With any AVR-DOS function in your code (for example uncomment FS_Interpreter.bas) this should not occur.
Next release of the MMC-Driver will compile without any problem.
regards Josef
Jeje
PostPosted: Wed May 11, 2005 8:27 am    Post subject: Problems compiling "Test_DOS_Drive.bas" Reply with quote
Ok, compiles fine now, excellent.
Thanks a lot!
Daniel.
