Posted: Mon Mar 31, 2008 11:25 pm Post subject: Brownout fuse settings
Hello all!
What are the brown out setting supposed to do exactly on the mega 48?
Does the processor restart itself if it reaches this point? What is considered the best use of this setting, and what is the best setting to use?
Thank you!
Tim
Check the details from the Atmel site on that processor for how the brownout works.
Normally you select a voltage just lower than your supply voltage, then the processor resets at the earliest possible moment, before it runs amok and the robot its controlling cuts your head off _________________ Adrian Jansen
Posted: Mon Apr 21, 2008 11:24 pm Post subject:
To expand, you should set the brownout level just over the min voltage at which you expect the whole system still to function. Yes the processor might still work at say 2.7 volts, but will the rest of the system respond to processor signals at 2.7 volts ? If not, you should set the brownout at 4.3 volts. _________________ Adrian Jansen
