ecoology
Joined: 07 Nov 2006 Posts: 340 Location: USA - California
Posted: Tue Jul 22, 2008 12:29 am Post subject: Timer0 problem |
This is probably going to be one of those "you're a dummy questions."
I want to use timer0 as an interrupt timer. This should be simple. I am using the mega324, BASCOM 1.11.9.2
Config Timer0 = Timer , Prescale = 64 : Stop Timer0
Enable Interrupts 'allow interrupts to occur
On Ovf0 Tim0_isr:
Timer0 = 0 : Enable Timer0 : Start Timer0
Toggle portd.0
Tim0_isr:
Stop Timer0 : Disable Timer0
Reset Portd.0
Waitms 100
Goto Begin
I set up the timer, then start it. To see where I am going, I go into an infinite loop, toggling portd.0 at about 1ms intervals. If I get to the ISR, I would see portd.0 stay low for 100ms.
I never get to the ISR. Portd.0 just keeps toggling forever at a 1ms rate.
Can some kind sole point out what I am doing wrong? I do not have much more hair to pull out! |
Posted: Tue Jul 22, 2008 1:39 am Post subject: |
You dont have a label for Begin, which might do a reset.
I would do it more like this: ( untested code ! )
On Ovf0 Tim0_isr:
dim bTimerFlag as byte
if bTimerflag.0 = 1
reset bTimerflag.0
disable timer0
reset portd.0
waitms 100
enable timer0 'if you want it to repeat
else
Toggle portd.0
end if
Tim0_isr:
set bTimerFlag.0
The way you had it, it would probably only get the IRQ once, then stop, since you disable the timer IRQ. _________________ Adrian Jansen
Visovian
Posted: Tue Jul 22, 2008 7:42 am Post subject: |
Code: | Tim0_isr:
Reset Portd.0
Waitms 100
Goto Begin
Return |
When entering ISR, all interrupts are automatically disabled. You need not Disable Timer0.
And interrupts are reenabled at exit from isr (with asm command RETI).
In your example how do you reach the end of Tim0_isr?
When you jump from isr with GOTO without returning (which I do not like too much), then the subroutine should end with RETI:
Begin:
'some code
!reti |
I hope I am not wrong. |
ecoology
Posted: Tue Jul 22, 2008 5:00 pm Post subject: |
Almost out of hair...
Fading fast!
I've tried the suggestions offered, plus a lot more. It seems nothing will cause the timer0 to time out and jump to the ISR. The code I currently have is:
Dim Readreg as bit
On Ovf0 Tim0_isr:
Readreg = 0
Start timer0
If Readreg = 1 Then
Reset Portd.0 ' pull portd.0 low to see ISR effect
Readreg = 0
Waitms 100
Set Portd.0 'toggle Portd.0 fast
Waitms 1
Reset Portd.0
Waitms 1
Tim0_isr:
Stop Timer0
Readreg = 1
Reset Timer0
Start Timer0
I am missing something here. I hope someone can point out what I am sure is the obvious. |
DToolan
Posted: Tue Jul 22, 2008 5:16 pm Post subject: |
** Removed **
ecoology
Posted: Tue Jul 22, 2008 5:44 pm Post subject: |
Using this code exactly, which I agree with, does not work. something else is going on.
I am using the mega324, and I've gone through the data sheet, but I do not see anything different from other megas. The processor works correctly in all respects except this. Now wondering if I have a defective chip - the timer0 is just bad????
This is one of those - ITS GOTTA WORK issues, but it doesn't
I am going to build up another board and see if this is an isolated case. |
ecoology
Posted: Tue Jul 22, 2008 6:01 pm Post subject: |
This is an example of "don't beat your brains in!"
I spent two days trying to get a simple interrupt using timer0 to work.
I just changed over to timer1, and it works!
There is a defect in the chip - timer0 is non-functional. Everything else works, and timer1 works as advertised.
Thanks for the inputs. Seeing that I wasn't that far off track led me to look at the chip itself. They can fail. It wasn't a BASCOM issue at all.
Long Live BASCOM! |
rileyesi
Posted: Tue Jul 22, 2008 6:19 pm Post subject: |
Ecoology,
This may or may not help, but years ago I designed a board using the old 4433 chip. Out of sheer dumb (bad!) luck, I used three pins on port b to dirve a D to A converter. A while later, I used the same board on a different design that needed to use timer0. I could not get it to work no matter what I did.
Then, I read the data sheet more closely and found (to my horror) that you needed port b to be able to use the timer0! (or something like that. My memory is kinda fuzzy on the details. maybe because I blocked them out!)
I did not look at the data sheet for your chip. Maybe there is a similar problem??
Hope this helps.
Pete |
ecoology
Posted: Tue Jul 22, 2008 6:24 pm Post subject: |
I'll take a look, but I don't recall seeing anything like that. These chips are so complex, that who knows? Anything is possible. All I know right now is that timer1 works perfectly, and timer0 is dead. out of a couple million transistor-equivalents, it only takes one failure to stop a function if not the whole chip. |
rileyesi
Posted: Tue Jul 22, 2008 6:33 pm Post subject: |
One other thought.
The following is a code snippet from one of the sample programs that came with BASCOM:
Config Clock = Soft 'this is how simple it is
'The above statement will bind in an ISR so you can not use the TIMER anymore!
Maybe???
Pete |
ecoology
Posted: Tue Jul 22, 2008 6:38 pm Post subject: |
Interesting, but I am not using any config clock statments.
I am still in trouble because the timer1 is a 16 bit timer. Even with prescale = 1, I can't get a fast enough timout. Best I get is about 120 ms. I need a timout of about 20 ms.
Maybe a Config clock not so soft??? |
rileyesi
Posted: Tue Jul 22, 2008 6:46 pm Post subject: |
I have a program that needs 50 ms loops and I simply use the WAITMS command. I could not get it to run using the TIMERs.
I'm not saying that it can't be done by someone smarter than me!
Good luck.
Pete |
ecoology
Posted: Tue Jul 22, 2008 7:05 pm Post subject: |
These timers should be simple to use. They were designed for interrupt operations, and the BASCOM commands were intended to use as int generators. we are not doing anything so complicated, why would the timers be such a pain?
Timer1 does work well, just not fast enough. its timer0 that seems to be a problem.
It seems like there is something in configuring the timer.
I've had other problems setting registers directly. I prefer to manipulate the registers so I know exactly what is going on, but that has pitfalls. i've sent a message to Mark, asking for clarification on how to handle the registers. Maybe the BASCOM command is not setting something for timer0? |
Posted: Tue Jul 22, 2008 11:06 pm Post subject: |
To get timer1 to have an 8 bit timeout period, just set its hi byte to &hff, and if course its low byte to 0. Be aware that you need to set the hi and lo bytes in the correct order - write the hi byte first. Bascom handles this correctly if you just do:
Timer1 = &hff00
You certainly seem to have problems with timer0, or maybe just that chip. I dont have that specific processor handy, but I certainly use timer0 with other processors ( AtMega64, 644, 16, 32 ) without problems. _________________ Adrian Jansen
ecoology
Posted: Tue Jul 22, 2008 11:12 pm Post subject: |
Thank you, Adrian.
Yes, I am having far more than reasonable issues with timer0. Others have commented that they have had problems too, so I don't feel like the Lone Ranger, but it is frustrating to waste so much time on seemingly simple things.
I'll play with your suggestion.
George |
