Posted: Fri Apr 11, 2008 3:21 pm Post subject: Sending large amounts of data to SPI
I am trying to load an external DSP part with code which is stored as data in my Bascom Code. It is 7680 bytes. If I send it all out at once I only need to set up the receiving address once but if I do it in chunks I need to send the new offset address for each chunk making larger bursts much faster. The 255 byte limit becomes a hassle however. This could be overcome by sending 192 bytes x 40 SPIout commands.
While I can send it using an array such as DSPDATA(195) which is 3 bytes of address and 192 bytes of data and repeat 40 times, I am unclear as to how to get the data and the address into the array efficiently. Unless I am missing something this would require a loop of 192 lookup or read functions.
Does the data for an SPIout have to be a single variable or can you put multiple variables in the statment like SPIout A, B, C, 3 ?
If you have the data in a large table (using Data/Read, or stored into program memory) you can use a for/next type loop and send bytes directly to the SPI port without using SpiOut. That way there is no 255 byte limit.
Something like this:
dim i asbyte dim temp asbyte 'insert code here to write the necessary address/header data to SPI for i =1to NumBytes
read temp
SPDR = temp 'write the byte to the SPI data register bitwait SPSR.SPIF , set'and wait till it has been sent next i
_________________ If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.5
