Brownout fuse settings
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
AdrianJ
PostPosted: Mon Mar 31, 2008 11:25 pm    Post subject: Brownout fuse settings Reply with quote
Hello all!
What are the brown out setting supposed to do exactly on the mega 48?
Does the processor restart itself if it reaches this point? What is considered the best use of this setting, and what is the best setting to use?
Thank you!
Tim
Check the details from the Atmel site on that processor for how the brownout works.
Normally you select a voltage just lower than your supply voltage, then the processor resets at the earliest possible moment, before it runs amok and the robot its controlling cuts your head off Twisted Evil
Adrian Jansen
AdrianJ
PostPosted: Mon Apr 21, 2008 11:24 pm    Post subject: Reply with quote
To expand, you should set the brownout level just over the min voltage at which you expect the whole system still to function. Yes the processor might still work at say 2.7 volts, but will the rest of the system respond to processor signals at 2.7 volts ? If not, you should set the brownout at 4.3 volts.
Adrian Jansen
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
