dcorrick
Posted: Wed May 11, 2005 11:06 pm Post subject: TLC5615 DAC interface using Software SPI |
I am attempting to interface a TLC5615 DAC using a Software SPI connection to a Mega8 processor. Problem is that the software SPI sends data LSB first, and I need to send it MSB first. If there any easy way to convert the two bytes, maybe using an EEprom look-up table so the data will be in the right order? Or is there an easy way to make the SPI connection send MSB first? Any Ideas would be appreciated.
Thanks |
rredding
Posted: Thu May 12, 2005 2:42 am Post subject: |
Maybe try this. It consumes lots of clock cycles so it will work if you are not in a hurry. I have not tested it so check my syntax. The eeprom method uses far less clock cycles and
I have used that method before.
'Yourdata holds the original data
'Backwards will hold the flipped data
Dim N As Byte
Dim Yourdata As Byte
Dim Backwards As Byte
Dim Position As Byte
Backwards = 0
For N = 0 To 7
Position = 7 - N
If Yourdata.n = 1 Then
Backwards = Bits(position)
Next |
rredding
Posted: Thu May 12, 2005 2:51 am Post subject: |
OOPS! That code doesn't work!
Just goes to show, don't post til I've tested!
Backwards needs to be OR'ed with the newly set bit position
Dim Temp As Byte
Dim N As Byte
Dim Temp As Byte
Backwards = 0
For N = 0 To 7
Position = 7 - N
Temp = Bits(position)
Backwards = Backwards OR Temp
Hope I'm actually helping here.....be warned, I still have not tested it |
rredding
Posted: Thu May 12, 2005 3:35 pm Post subject: |
Yup, me again. Have you looked at the "SHIFTOUT" instruction?
That gives the MSB / LSB first option. |
dcorrick
Posted: Thu May 12, 2005 11:22 pm Post subject: |
Thanks for all of your suggestions. I tried the Shiftout command last week, and I couldn't get it to work. I took your original suggestion, and put it in a For Next loop, starting at 0 to 255, and generated the numbers in reverse, and stored them in EEprom, which then makes for a fast lookup. I got it working this afternoon. Thanks again for your help. In case someone else might run into this problem, I will post the program here.
$regfile = "m8def.dat"
'tell the compiler which XTAL was used
$crystal = 4000000
Dim Temp As Byte
Dim E As Byte
Dim N As Byte
Dim B As Byte
Dim C As Byte
Dim A As Byte
Open "comc.0:38400,8,n,1,inverted" For Output As #2
For E = $00 To $ff
Yourdata = E
B = 0
Temp = 0
For N = 0 To 7
Shift Temp , Left , 1
Position = 7 - N
Temp = Temp Or $01
Next N
B = Temp
Writeeeprom B , E
Readeeprom A , E
Print #2 , "E" ; E ; " NUMBER " ; A
Next E
Close #2
End 'end program |
philm
Posted: Fri May 13, 2005 2:01 am Post subject: |
Try Code: | dim in_byte As Byte
dim out_byte as byte
declare function swap_bits(inbyte as byte) as byte
input "byte ", in_byte
print "Binary "; bin(in_byte)
out_byte = swap_bits (in_byte)
print "Swapped Binary "; bin(out_byte)
local in_cnt as byte, out_cnt as byte
swap_bits = 0 'by default = 0
out_cnt = 7 'Out bit counter
for in_cnt = 0 to 7 'In bit counter
if inbyte.in_cnt = 1 then set swap_bits.out_cnt
decr out_cnt 'Out bit counts backwards
next in_cnt 'In bit counter counts forwards
end function |
But a better solution is to use the harware SPI |
