Need Help MAX7456
Goto page 1, 2, 3, 4  Next
Joshua314
PostPosted: Fri Mar 07, 2008 10:43 am    Post subject: Need Help MAX7456 Reply with quote
Hello @ all,
i have a MAX7456 OSD from Maxim.
I wrote a simple Source for it.
But the source doesn't work.
Have everyone a Idee ???
Thank's Thomas
'                           MAX7456
'                          (c) DG5MPQ  01/2008
$regfile = "M8def.dat"
$crystal = 8000000
$baud = 38400
Const Vm0 = &H00                                            ' Video Mode 0
Const Vm1 = &H01                                            ' Video Mode 1
Const Hos = &H02                                            ' Horizontal Offset
Const Vos = &H03                                            ' Vertical Offset
Const Dmm = &H04                                            ' Display Memory Mode
Const Dmah = &H05                                           ' Display Memory Address High
Const Dmal = &H06                                           ' Display Memory Address Low
Const Dmdi = &H07                                           ' Display Memory Data In
Const Cmm = &H08                                            ' Character Memory Mode
Const Cmah = &H09                                           ' Character Memory Address High
Const Cmal = &H0A                                           ' Character Memory Address Low
Const Cmdi = &H0B                                           ' Character Memory Data In
Const Osdm = &H0C                                           ' Osd Insertion Mux
Const Rb0 = &H10                                            ' Row 0 Brightness
Const Rb1 = &H11                                            ' Row 1 Brightness
Const Rb2 = &H12                                            ' Row 2 Brightness
Const Rb3 = &H13                                            ' Row 3 Brightness
Const Rb4 = &H14                                            ' Row 4 Brightness
Const Rb5 = &H15                                            ' Row 5 Brightness
Const Rb6 = &H16                                            ' Row 6 Brightness
Const Rb7 = &H17                                            ' Row 7 Brightness
Const Rb8 = &H18                                            '  Row 8 Brightness
Const Rb9 = &H19                                            ' Row 9 Brightness
Const Rb10 = &H1A                                           ' Row 10 Brightness
Const Rb11 = &H1B                                           ' Row 11 Brightness
Const Rb12 = &H1C                                           ' Row 12 Brightness
Const Rb13 = &H1D                                           '  Row 13 Brightness
Const Rb14 = &H1E                                           ' Row 14 Brightness
Const Rb15 = &H1F                                           ' Row 15 Brightness
Const Osdbl = &H6C                                          ' Osd Black Level
Const Stat = &HA0                                           ' Status
Const Dmdo = &HB0                                           ' Display Memory Data Out
Const Cmdo = &HC0                                           'Character Memory Data Out
Mosi Alias Portc.0
Config Mosi = Output
Miso Alias Pinc.1
Config Miso = Input
Sck Alias Portc.2
Config Sck = Output
Cs Alias Portc.3
Config Cs = Output
Res Alias Portb.0
Config Res = Output
Los Alias Pinb.1
Config Los = Input
Declare Sub Max7456out(daten As Byte)                       ' Schreibt 8 bit zum OSD
Declare Sub Max7456outb(byval Daten_b As Byte)
Declare Sub Max7456cs(byval Was As Byte)
Declare Function Max7456in() As Byte
Print "{013}MAX7456 Test"
Dim Help As Byte
Dim T As Byte
'Do
Print "Reset low"
 Reset Res
 Waitms 10
 Set Res
 Waitms 200
Print "Reset hi"
Call Max7456cs(0)
 Call Max7456outb(vm0)
 'Call Max7456outb(&B01001000)                               ' 1001100
 Call Max7456outb(&H4c)                                     ' 1001100
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(osdbl)
  Print Max7456in()                                         ' 00001001
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(&H07)                                     ' 00001001
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(dmah)
 Call Max7456outb(&H00)
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(dmm)
 Call Max7456outb(&B01000000)
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(dmal)
 Call Max7456outb(&H20)
Call Max7456cs(1)
Call Max7456cs(0)
 Call Max7456outb(dmdi)
 Call Max7456outb(&H0b)
Call Max7456cs(1)
Waitms 5000
'Loop
  Call Max7456out(daten_b)                                  ' Schreibt 8 bit zum OSD
End Sub
Function Max7456in() As Byte                                ' Schreibt 8 bit zum OSD
 For Help = 7 To 0 Step -1                                  ' Wir haben 8 Bit MSB zu LSB
  Set Sck                                                   ' Clock anmachen
   Print "^";
  Reset Sck
   Print "!";                                               ' Clock wieder ausmachen
  If Miso > 0 Then                                          ' Ist das Bit gesetzt
   Set T.help
   Print "1";
  Else
   Reset T.help
   Print "0";                                               ' oder loeschen
 Next Help                                                  ' Und weiter
 Print ":" ; T ; ":" ; Hex(t);
 Max7456in = T
End Function
 Print Daten ; ":" ; Hex(daten) ; ":";
  If Daten.help > 0 Then                                    ' Ist das Bit gesetzt
   Set Mosi                                                 ' Dann bit high machen
   Print "1";
  Else
   Reset Mosi
   Print "^";
  'For T = 1 To 5 : Next T
  'Waitms 10
  Reset Sck
   'Waitms 10
  Print " "
End Sub
 Local I As Byte                                            ' Dummy
  If Was = 0 Then
   Reset Sck                                                ' Erst mal den Clk nach unten
   Reset Cs
   Print "!."
  Else
   Set Cs
   Print "'"
End Sub
yah996
PostPosted: Sat Aug 09, 2008 10:11 pm    Post subject: Reply with quote
any update on that?
http://www.grautier.com/grautier/index.php?/archives/60-C2OSD-V1.0.html#extended
Thanks,
K.
pseddon
PostPosted: Sun Aug 10, 2008 4:14 pm    Post subject: Reply with quote
I don't see a config spi or spiinit statement for a start.
I would suggest you look at the examples for using SPI to see how to read from and write to the SPI port.
regards Peter
yah996
PostPosted: Sun Aug 10, 2008 8:23 pm    Post subject: Reply with quote
Here is my first code...
I tried to keep it simple. Also i tried SHIFTOUT command. No sucess yet.
$regfile = "M644def.dat"
$crystal = 18432000
$hwstack = 32
$swstack = 32
$framesize = 32
Declare Sub Send_spi
Open "com1:115200,8,n,1" For Binary As #1
Dim B As Byte
Dim Regaddr As Byte
Dim Regdata As Byte
' MAX7456 PIN.8 = Porta.7 ' SPI_CS
' MAX7456 PIN.9 = Porta.4 ' Dion
' MAX7456 PIN.10 = Porta.6 ' SPI_CK
' MAX7456 PIN.11 = Porta.5 ' Dout
Config Spi = Soft , Din = Porta.4 , Dout = Porta.5 , Ss = Porta.7 , Clock = Porta.6
Spiinit ' Init SPI
Print "MAX7456 DEMO"
'01001000' ; 0 , 1=PAL, 00=Auto Sync, 1=Enable OSD, 0=Enable OSD immer, 0=SW RST, 0=Enable Video Buffer
Regaddr = &H00
Regdata = &B01001000
Call Send_spi
'00010100' ; 0 = NA, 001=Background MODE Brightness 7%, 11=Blinking Time 160ms, 00=Blinking Duty Cycle BT:BT
Regaddr = &H01
Regdata = &B00010100
Call Send_spi
'00100000' ; 00=NA, 100000=No Horitzontal offset
Regaddr = &H02
Regdata = &B00100000
Call Send_spi
'00010000' ; 000=NA, 100000=No Vertical Offset
Regaddr = &H03
Regdata = &B00010000
Call Send_spi
Waitms 500
Regaddr = &H05
Regdata = &B00000000
Call Send_spi
Regaddr = &H06
Regdata = &B00000001
Call Send_spi
Regaddr = &H07
Call Send_spi
Sub Send_spi
B = Regaddr
Spiout B , 1
B = Regdata
Spiout B , 1
End Sub
Antony(uk)
PostPosted: Tue Aug 12, 2008 9:18 pm    Post subject: Reply with quote
Hi
Did you get this working as I have just sent off for my samples.
This would offer a cheap and easy method of On Screen Display.
There are a lot of software samples out there all in "C".
I will wait for my samples before I start on this one.
Regards Antony(UK)
steffus
PostPosted: Tue Oct 21, 2008 9:33 pm    Post subject: Reply with quote
Any good news?
Reg
Steffen
yah996
PostPosted: Wed Oct 22, 2008 1:22 pm    Post subject: Reply with quote
It pretty simple (Here is my basic code to get this working...)
$crystal = 18432000
$hwstack = 32
$swstack = 32
$framesize = 32
'** Configuration ****************************************
Declare Sub Read_spi
Open "com1:57600,8,n,1" For Binary As #1
$baud = 115200
Dim In_str As Byte
Dim B As Byte , X As Byte , I As Byte
Dim Regaddr As Byte
Dim Regdata As Byte
Print "MAX7456 ASM SPI-Mode"
Print "www.silicon-racing.com"
print "mail to yah996@yahoo.com to get the complete code""
Config Spi = Hard , , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 0
Spiinit
Regaddr = &H00
Regdata = &B01001100
Call Send_spi
Regaddr = &H01
Regdata = &B01110100
Call Send_spi
''00100000' ; 00=NA, 100000=No Horitzontal offset
Regaddr = &H02
Call Send_spi
Regaddr = &H03
Call Send_spi
For I = 1 To 100
Regaddr = &H05
Regdata = &H00
Call Send_spi
Regaddr = &H06
Regdata = I
Call Send_spi
Regaddr = &H07
Regdata = I
Call Send_spi
Next I
Loop ' never reached
Sub Send_spi
$asm
lds r17,{Regaddr}
Out Spdr , R17
Waitspi_1:
sbis spsr,7
rjmp WaitSPI_1
lds r17,{Regdata}
Out Spdr , R17
Waitspi_2:
sbis spsr,7
rjmp WaitSPI_2
$end Asm
End Sub
Sub Read_spi
End Sub
tolisn
PostPosted: Wed Oct 22, 2008 5:20 pm    Post subject: Reply with quote
I'm trying to overlay a scale for comparison on a parking camera that I just installed in my car.
I would like it to look something like the photo.
Do you think that it can be done with this chip and Bascom using a ATmega8?
yah996
PostPosted: Wed Oct 22, 2008 6:08 pm    Post subject: Reply with quote
Yes!
Your Mega needs to have a Hardware SPI and some bytes of RAM.
tolisn
PostPosted: Wed Oct 22, 2008 6:50 pm    Post subject: Reply with quote
Thanks for the reply.
1. Looking at your code above, is the "For I... loop responsible for putting the characters on the screen?
2. Can you put the characters into a desired location on the screen and how ?
While I'm waiting for the sample I though I should do a little homework Very Happy
mextal
PostPosted: Mon Dec 15, 2008 4:34 pm    Post subject: Reply with quote
Hello,
I have a project with the max7456 and i have text on screen but if i use de default offset for collum/row the not all charators are visable ??
Has some one a solution for this?
Tiny
yah996
PostPosted: Mon Dec 15, 2008 7:54 pm    Post subject: Reply with quote
mextal wrote:
Hello,
Tiny
Hello,
do you have a picture? What kind of monitor are you using? Real television monitor?
I had some troubles with an PC tv-card...
Greets,
K.
Evert :-)
PostPosted: Mon Feb 23, 2009 2:04 pm    Post subject: Reply with quote
For everybody how is interested i have made some routines for the MAX7456 video overlay in Bascom.
Also included a tool to make your own characters.
Read more HERE.
Antony(uk)
PostPosted: Mon Feb 23, 2009 3:01 pm    Post subject: Reply with quote
Hi Evert
That’s so nice...I have been playing with this for sooooo long.
I know I am a pain in the neck...But could you please do a connection drawing or point me in the right direction..
I have been using the BOB4 system But its bulky.
Regards Antony(UK)
B.T.W. is it possible to display a variable directly :- Videotext variable, y , x
Evert :-)
PostPosted: Mon Feb 23, 2009 4:13 pm    Post subject: Reply with quote
Hi Anton,
Schematic is really simple, is the same as in the datasheet. Schematic that i used is attached (login to see)
Connected it with hardware SPI to an M128, so it should work with every AVR with a spi bus. Didn't tested it with software SPI bus.
Of course you can work with variable, variable and text string together must be done in 2 steps. You know that Bascom only want to do 1 think at each line.
A= 123
Temptextstring = "Hello world " + A + " greetings"
Videotext Temptextstring , 2 , 3
Page 1 of 4
