DIM or LOCAL inside a Sub
PeterPiper
PostPosted: Thu Mar 06, 2008 10:31 pm    Post subject: DIM or LOCAL inside a Sub Reply with quote
What's the difference between dimensioning a variable within a sub routine, using DIM, as opposed to using LOCAL?
AdrianJ
PostPosted: Fri Mar 07, 2008 1:00 am    Post subject: Reply with quote
Dim declares the variable as global, regardless of the fact that its in a Sub. You must use Local if you want it local to that sub.
Adrian Jansen
Luciano
PostPosted: Fri Mar 07, 2008 6:11 pm    Post subject: Reply with quote
See Bascom AVR help file DIM and LOCAL.
SCOPE
The scope for DIM is global. So no matter where you use the DIM statements, the variable will
end up as a global visible variable that is visible in all modules, procedures and functions.
When you need a LOCAL variable that is local to the procedure or function, you can use LOCAL.
A LOCAL variable is a temporary variable that is stored on the frame.
When the SUB or FUNCTION is terminated, the memory will be released back to the frame.
Since LOCAL variables are stored on the frame, it takes more code to dynamic generate and clean up these variables.
Local BIT variables are not possible because they are GLOBAL to the system.
See this thread about stack: (The Frame).
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=3220
Best regards,
Luciano
PeterPiper
PostPosted: Sun Mar 09, 2008 5:13 am    Post subject: Reply with quote
Thanks. The "manual" isn't too clear about dimensioning using DIM inside or outside of a sub routine.
