rayhall
Posted: Sun Jan 27, 2008 11:29 pm Post subject: Bug in compiler or in me? |
The first code works and the correct values are passed to the Dbw_pid sub. The second seems to be getting very low or zero values. I cannot see why.
I am using the Mega2561, and compiler version 1.11.9.0
Ray.
Code: | Dim Running As Bit
Dim Rpm As Word 'Engine RPM
Dim Tps_main As Integer 'Foot pedal main signal
Dim Tps_sub As Integer 'Foot pedal sub signal
Dim Tb As Integer 'Throttle body position
Dim Tps As Integer 'Foot pedal position
Dim Idle_offset As Integer 'Idle rpm offset
'{---------------------- Timer0 --------------------------}
Timer_0:
Tps_main = Getadc(0) 'Pedal throttle position main signal
Tps_sub = Getadc(1) 'Pedal throttle position sub signal
Tps = Tps_main + Tps_sub
Tps = Tps / 2 'Calculate the average of both signals
Tb = Getadc(2) 'Throttle body position main signal
If Running = True Then 'If engine running
If Tps < Idle_limit And Rpm < 1500 And Fastidle = False Then
Tps = Tps + Idle_offset
If Ac_on = True And Tps < Idle_limit Then 'If AC on, then add offset
Tb = Tb - Ac_offset_val
Call Dbw_pid(tps , Tb) 'Call throttle motor control PID
Else 'If engine not running
Return |
Dim Tb_t As Integer 'Throttle body temp position
Dim Tps_t As Integer 'Foot pedal temp position
Timer_0:
Tps_t = Tps + Idle_offset
Tb_t = Tb
Tb_t = Tb - Ac_offset_val
Tps_t = Tps
Call Dbw_pid(tps_t , Tb_t) 'Call throttle motor control PID
Return |
ZOHAIB
Posted: Mon Jan 28, 2008 10:33 am Post subject: |
hi!
dont declare the variable which are storing adc value as integer declare them as word
regards |
Luciano
Posted: Mon Jan 28, 2008 10:37 am Post subject: |
Hi Ray,
What are the used stack values?
Code: | $hwstack = ??
$swstack = ??
$framesize = ?? |
Luciano |
for_ro
Posted: Mon Jan 28, 2008 4:35 pm Post subject: |
there is a slight change in your code as well.
In the top code, tps and tb are always set to ADC values and handed over to the Dbw_pid function
In the second code, the arguments of the function (tps_t and tb_t ) are only set, if tps < idle_limit. Otherwise they will remain on 0.
Only if the engine is not Running (Running=True) the function is directly called with tps and tb.
Additionally I wouldn't do that much calculation in the Timer0 ISR.
Rolf |
rayhall
Posted: Thu Jan 31, 2008 11:03 am Post subject: |
Luciano,
This is what I am using.
$hwstack = 512
$swstack = 512
$framesize = 512
Ray. |
rayhall
Posted: Sat Feb 02, 2008 8:00 am Post subject: |
Rolf,
Thank you..You were correct. Adding this made sure they did not have zero values
Tb_t = Tb
Tps_t = Tps
This is the code fixed.
Timer_0:
Tb_t = Tb '********
Tps_t = Tps '*******
Tb_t = Tb
Tps_t = Tps
Return |
