Save bgf into at45db081
SteveT
PostPosted: Sat Feb 02, 2008 7:21 am    Post subject: Save bgf into at45db081 Reply with quote
Hello
I want save into at45db081 (external memory) a bgf and show on graphic display
I can do the software for PC to upload the file create with Tools/Graphic Converter, and SAVE into memory with the same format.
My interrogation is : it's possible to load the picture from external memory and use the showpic on graphic display
I need about 100 to 150 differents small pictures and i want keep the memory on Mega128 for the firmeware,
Thank you for help
Steve
PostPosted: Sat Feb 02, 2008 11:39 am    Post subject: Reply with quote
Hi Steve,
Take a look at this application note; http://www.mcselec.com/index.php?option=com_content&task=view&id=96&Itemid=57
SteveT
PostPosted: Sat Feb 02, 2008 1:42 pm    Post subject: Reply with quote
Thamk you,
Over 80% of adjusted. Last think iy`s possible to know whee exactly the start and end of each picture, i need the replace or add some picture after the source was compiled
Thank you
Steve
