$eeprom problem
mariosm
PostPosted: Fri Feb 01, 2008 11:52 pm    Post subject: $eeprom problem Reply with quote
Hi All
I try to write seven numbers in eeprom with these code lines
$eeprom
Data 600 , 1200 , 2400 , 6000 , 12000 , 24000 , 60000
$data
After compiling the program i try to write the .eep file in the eeprom of a microcontroller (ATmega8515) with my ISP programmer.
I see on my screen a label with this :" Error at line 1!. Line must begin with ":" character!".
Who is the problem?
Marios
..( My programmer is USB AVRprog with AVRFLASH Programmer 2.10 software from Microelectronica)
PostPosted: Sat Feb 02, 2008 10:34 am    Post subject: Reply with quote
You need o define a label for your data. The example in the help text is:-
'copyright                : (c) 1995-2005, MCS Electronics
'micro                    : AT90S2313
'suited for demo          : yes
'commercial addon needed  : no
'purpose                  : demonstrates $DATA directive
$regfile = "2313def.dat"
$baud = 19200
$crystal = 4000000                                          ' 4 MHz crystal
Dim B As Byte
Readeeprom B , 0                                            'now B will be 1
Dta:
$eeprom
Data 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8
$data
Note the Dta: line.
Ian Dobson
Luciano
PostPosted: Sat Feb 02, 2008 2:01 pm    Post subject: Reply with quote
Integer and Word constants must end with the %-sign.
Long constants must end with the &-sign.
Single constants must end with the !-sign.
Double constants must end with the #-sign.
Example:
Dta:
$eeprom
Data 1 , 20 , 255  'these are bytes, each value will use 1 byte of EEPROM.
Data 1%, 20%, 255%, 32767%  'these are integers, each value will use 2 bytes of EEPROM.
Data 1%, 20%, 255%, 65535%  'these are words, each value will use 2 bytes of EEPROM.
Data 1&, 20&, 255&, 65535&, 2147483647&   'these are longs, each value will use 4 bytes of EEPROM.
Data 1.123!, 123.456! 'these are singles, each value will use 4 bytes of EEPROM.
Data 1.123#, 123.456# 'these are doubles, each value will use 8 bytes of EEPROM.
$data
Luciano
JohnCannon
PostPosted: Sat Feb 02, 2008 10:23 pm    Post subject: Reply with quote
Nice Post, Luciano,
Where, within Bascom, is this information? I didn't find it in HELP.
JC
Luciano
PostPosted: Sat Feb 02, 2008 10:45 pm    Post subject: Reply with quote
Hi John,
See help file DATA.
Luciano
mariosm
PostPosted: Sun Feb 03, 2008 1:28 pm    Post subject: Reply with quote
Thank you for your answers i.dobson and Luciano.
I find the problem. I should have used $eepromhex command
because my programmer need the hex format of .eep file.
Thanks for all
Marios
