fs_interpreter problems - no commands recognised
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
mattcro
PostPosted: Mon Jan 28, 2008 2:40 pm    Post subject: fs_interpreter problems - no commands recognised Reply with quote
Hi all,
I've just started using AVRDOS and am trying the test_dos_drive demo with fs_interpreter on a M128.
The SD card is detected and initialised OK (I have previously used this setup/card with raw low-level SD access), but the command interpreter does not recognise any commands. Sample output:
Wait for Drive
Init File System ...  OK
Filesystem: 139
FAT Start Sector: 36
Root Start Sector: 1968
Data First Sector: 1968
Max. Cluster Nummber: 123383
Sectors per Cluster: 8
Root Entries: 0
Sectors per FAT: 966
Number of FATs: 2
AVR-DOS: Ready for commands
0000>cfi
Command 'cfi' not recognized
0000>dir
Command 'dir' not recognized
0000>
I haven't changed anything in the demo files apart from SPI/MMC config, and am using the files supplied with Bascom 1.11.9.0. I've tried increasing stack/frame sizes with no effect. I've just started some simple debugging, which indicates that the commands are not being tokenised correctly in Extracttoken (in fs_interpreter.bas)
Does anybody else have this problem? Have I missed something simple?
Cheers,
Matt
If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.5
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
