Posted: Sun Jan 06, 2008 2:18 am Post subject: AVR-DOS - Read/Write Double variables
over little debuging we found problem when you want try to read/write DOUBLE variables into text files, for example with this code:
Dim dbl_var asDouble
Open"test.txt"ForOutputAs #3 Write #3 , dbl_var
Close #3
Open"test.txt"ForInputAs #3 Input #3 , dbl_var
Close #3
You get compile errors about missing some labels [_dbl_bin2asc]. If you get this type of errors, workaround is simple:
- open avr-dos.lbx file
- search for:
[_FileWriteDecDouble]
$EXTERNAL _FileWrite_StrBuf
and replace with:
$EXTERNAL _FileWrite_StrBuf , _dbl_bin2asc
- next search for:
[_FileReadDecDouble]
$EXTERNAL _FileReadString
and replace with:
$EXTERNAL _FileReadString, _Dbl_ASC2Bin
- save file
Now when you compile program it should compile without errors.
In some situation you can get also error about missing labe [_DIV16], solution for this is simple, just place in your main program this directive :
$external _div16 _________________ Best regards,
/Tomi
