pinkfloyd11
Posted: Wed Dec 19, 2007 8:09 pm Post subject: Why Cristal don't oscillate?? |
Dear Friends
I have realized a program on ATmega8515 and it work good when run on STK500.
After I have realized a prototype on bread board using the same cristal placed on stk500. The pin of cristal are placed between Xtal1 and Xtal2.
From the same pin 2 condenser of 33pF go to gnd.
The clock fuse bit selected is:
Ext. RC Osc. 8MHz - 12 MHz StartUp time : 6CK+4ms
Why I do not view oscillation when place the scope on pin 19?
Thanks |
SteveT
Posted: Wed Dec 19, 2007 8:46 pm Post subject: |
Hello,
Check for clean connection without FLUX. I have already this probleme with SOLDER containt WATER SOLUB FLUX. And check for your power supply, to avoid to much ripple on the supply line, The evaluation board have a good filtration....
Steve
ps. You have seen that my English is a bit special, excuse me |
Luciano
Posted: Wed Dec 19, 2007 9:38 pm Post subject: |
Wrong fuse if you use a 8MHz crystal.
AVR Studio 4.13
Use this setting:
Ext. Crystal/Resonator High Freq.; Start-up time: 16K CK + 64 ms
Best regards,
Luciano |
pinkfloyd11
Posted: Wed Dec 19, 2007 11:14 pm Post subject: |
Dear Luciano
I use 16MHz quartz.
In this case which is the best fuse?
Are 33pF correct value?
Thanks
Luciano wrote: | Hi,
AVR Studio 4.13
Use this setting:
Luciano
Posted: Thu Dec 20, 2007 9:28 am Post subject: |
For a 16MHz crystal use this setting:
Make sure you are using an ATmega8515 and not an ATmega8515L.
Speed Grades:
0 to 8 MHz for ATmega8515L
0 to 16 MHz for ATmega8515
Click to enlarge the picture
Best regards,
Luciano |
pinkfloyd11
Posted: Thu Dec 20, 2007 10:40 am Post subject: |
Hello
on chip there is this:
ATMEGA8515
16PU
0602
Howhewer on STK500 I have 16MHz crystal and when the same is placed on it, work good.
Thanks |
Luciano
Posted: Thu Dec 20, 2007 11:28 am Post subject: |
The crystal is used for the oscillator on the STK500.
When you plug an AVR chip into the sockets of the STK500
the AVR chip gets the TTL clock from the the oscillator on the STK500.
(See the STK500 manual for details).
The second clock option you have while using the STK500 is to
remove the jumper XTAL1 and use the internal RC oscillator of the AVR.
Best regards,
Luciano |
pinkfloyd11
Posted: Thu Dec 20, 2007 10:47 pm Post subject: |
Hello
I have set the fuse bit:
and now work good also on bread board!
Thanks |
