ADC on ATtiny13
john7
PostPosted: Wed Dec 05, 2007 12:13 pm    Post subject: ADC on ATtiny13 Reply with quote
Hi all!
I have some problems with ADC and Attiny13
I can'n get it working, PORTB.2 always high and no reaction
$regfile = "attiny13.dat"
$hwstack = 8
$swstack = 8
$framesize = 24
DDRB = &B00000011       '0 - input , 1 - output
PORTB = &B00000000
Config Pinb.2 = Input
'ADC settings
ADMUX = &B00000001       'internal ref,right adj,chan#1(pb2)
'Adcsra.7 = 1       'enable ADC
'Adcsra.6 = 0       'Stop ADC
'Adcsra.5 = 0       'autotrigger disabled
ADCSRA = &B10000110      ' prescaler = 64,
Const V_limit = 550
Dim Adc_val As Word
Gosub Get_current
Select Case Adc_val
    Case Is < V_limit : PORTB.0 = 0
    Case Is > V_limit : PORTB.0 = 1
Get_current:
  ADCSRA.6 = 1       'start ADC
  Adc_val = Getadc(1)
  ADCSRA.6 = 0       'stop ADC
john7
PostPosted: Wed Dec 05, 2007 3:08 pm    Post subject: Reply with quote
ok i got it working, but the adc pin PORTB.2 always high!
So i have to pull it down to change the voltage - it's reverse logic.
How can i set it to work normally?
Visovian
PostPosted: Wed Dec 05, 2007 8:42 pm    Post subject: Reply with quote
I think, you should decide to use either Bascom statements or your own control of io registers.
If former, then
Config Adc = Single , Prescaler = Auto
Dim Adc_val As Word
Adc_val = Getadc(1)
If latter, then
Dim Adc_val As Word
'ADC settings
  While ADCSRA.6 = 1  'wait until conversion complete
  Wend
  Adc_val = ADCH * 256
  Adc_val = Adc_val + ADCL
john7
PostPosted: Thu Dec 06, 2007 6:18 am    Post subject: Reply with quote
Thanks a lot . It seems to be working Smile
