Relaton between Software Clock and Fuse bit
pinkfloyd11
PostPosted: Tue Nov 27, 2007 4:40 pm    Post subject: Relaton between Software Clock and Fuse bit Reply with quote
Dear Friends
I have written a program that write on RS232 on ATMega8515 placed directly on STK500 Board.
I use software clock (XTAL1 jumper close; OSCSEL jumper close on 1-2)
set by AVR Studio board tab on 3.686 MHz
Now which fuse bit I should use on ATMega8515 for have RS232 communication work good (because I read strange word on rs232 an I know that this is clock error...)
If max software freq. is 3.686MHz why in list there are also 6 MHz, 8 MHz ecc and which is the difference between Int. Clcok, Ext Clock, Int osc ecc??
Thanks
Luciano
PostPosted: Tue Nov 27, 2007 6:24 pm    Post subject: Reply with quote
Hi Giuseppe,
Read the ATmega8515 datasheet from page 34 to page 40.
ATmega8515 datasheet:
http://www.atmel.com/dyn/resources/prod_documents/doc2512.pdf
Best regards,
Luciano
