M32 hangs @Config Tcpip with bascom samples.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP
dk_akj
PostPosted: Sun Nov 18, 2007 9:42 pm    Post subject: M32 hangs @Config Tcpip with bascom samples. Reply with quote
Hi all Bascommers.
I've bought a Easy TCP/IP developer board, a adapterbord and a nm7010a.
After figthing with it for 6 hours I need some help.
My problem is that nomather witch sample I test it hangs when entering this line:
Config Tcpip = Int0 , Mac = 12.128.12.34.56.78 , Ip = 192.168.0.25 , Submask = 255.255.255.0 , Gateway = 192.168.0.1 , Localport = 1000 , Tx = $55 , Rx = $55 , Twi = &H80 , Clock = 400000 , Timeout = 1000000
Header of bas file:
'name : PING_TWI.bas http://www.faqs.org/rfcs/rfc792.html
'purpose : Simple PING program
'micro : Mega88
'suited for demo : yes
'commercial addon needed : no
$regfile = "m32def.dat" ' specify the used micro
$hwstack = 128 ' default use 32 for the hardware stack
Const Cdebug = 1
Const Sock_stream = $01 ' Tcp
Const Sock_dgram = $02 ' Udp
Const Sock_ipl_raw = $03 ' Ip Layer Raw Sock
Const Sock_macl_raw = $04 ' Mac Layer Raw Sock
Const Sel_control = 0 ' Confirm Socket Status
Const Sel_send = 1 ' Confirm Tx Free Buffer Size
Const Sel_recv = 2 ' Confirm Rx Data Size
'socket status
Const Sock_closed = $00 ' Status Of Connection Closed
Const Sock_arp = $01 ' Status Of Arp
Const Sock_listen = $02 ' Status Of Waiting For Tcp Connection Setup
Const Sock_synsent = $03 ' Status Of Setting Up Tcp Connection
Const Sock_synsent_ack = $04 ' Status Of Setting Up Tcp Connection
Const Sock_synrecv = $05 ' Status Of Setting Up Tcp Connection
Const Sock_established = $06 ' Status Of Tcp Connection Established
Const Sock_close_wait = $07 ' Status Of Closing Tcp Connection
Const Sock_last_ack = $08 ' Status Of Closing Tcp Connection
Const Sock_fin_wait1 = $09 ' Status Of Closing Tcp Connection
Const Sock_fin_wait2 = $0a ' Status Of Closing Tcp Connection
Const Sock_closing = $0b ' Status Of Closing Tcp Connection
Const Sock_time_wait = $0c ' Status Of Closing Tcp Connection
Const Sock_reset = $0d ' Status Of Closing Tcp Connection
Const Sock_init = $0e ' Status Of Socket Initialization
Const Sock_udp = $0f ' Status Of Udp
Const Sock_raw = $10 ' Status of IP RAW
Dim X As Byte
Config Portc.2 = Output
Q_test Alias Portc.2
For X = 1 To 5
Print "Init TCP " + Str(x)
Wait 1
Toggle Q_test
' display a message
Reset Q_test
'we do the usual
Print "Enable interrupts"
Print "Enable interrupts - OK"
' before we use config tcpip , we need to enable the interrupts
Print "Init done"
Set Q_test
On my terminal I see:
Init TCP 1
Init TCP 2
Init TCP 3
Init TCP 4
Init TCP 5
Enable interrupts
But never:
"Init done"
q_test ( a LED) is flashing during for next, but is not set after the config either.
I cant ping the module, LED's are on, yellow led flashing (turns of for a few MS every 1-2 secs.
JTAG is disabled
Chip settings in bascom:
I2C settings (is this needed ?)
Compiler version :1.11.9.0
Compiler build :1.11.9.0.001
IDE version :1.11.9.0
Serial number :xxxxxxxxxxxxx
Windows OS :Microsoft Windows XP
Windows SP :Service Pack 2
Explorer :7.0.5730.11
Company :
Owner :Anders Kjær
Windows dir :C:\WINDOWS
App data dir :C:\Documents and Settings\Anders\Application Data
System dir :C:\WINDOWS\system32
Any ideas to solve this problem ??
Thanks in advance
Anders
View user's profile MSN Messenger
dk_akj
PostPosted: Mon Nov 19, 2007 8:34 pm    Post subject: Reply with quote
Problem solved, the dummy (me) had used 470R instead of 4K7 as pullups on TWI Embarassed
Anders
Post new topic   Reply to topic    www.mcselec.com Forum Index -> EASY TCP/IP All times are GMT + 1 Hour
