programming the 89S51
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
stein.john
PostPosted: Fri Nov 16, 2007 9:56 pm    Post subject: programming the 89S51 Reply with quote
I read the posting by x_dadu with great interest as I also needed
to program the 89s51 uP's which have pretty much replaced the older 89c51.
My solution was different to his as I had no programer at all.
I post it here in the hope it will be of use to others.
1) The programmer
Download the schematic from [url]www.btc.pl/pdf/zl9prg.pdf [/url]
The text is in Polish but don't worry as you will only need the schematic.
Although this document shows the zl9prg in surface mount, I built mine from "conventional" components.
In the schematic you will see an op-amp and a couple of other components that do an automatic detection of 3.3v or 5v.
If you don't need this feature, simply leave that section out when you build
the programer and simply connect pin 15 of the parallel port to 5v via a
4.7K ohm resistor.
Note that this programer also supports Atmel's "ATF" range of CPLDs.
2) The programming software.
Download it directly from Atmel at
http://www.atmel.com/dyn/resources/prod_documents/At89isp.zip
Please note that it's a hefty 6MB file called AT89isp.
Download Update 2.4 which adds support for the following chips:
AT89s8253,At89S2051,At89S4051 and a couple of others.
It's here http://www.atmel.com/dyn/resources/prod_documents/AT89ISP_Update2.4.zip
Download Update 2.5 which adds user selectable LPT ports
http://www.atmel.com/dyn/resources/prod_documents/AT89ISP_Update2.5.zip
A word of caution....the above software does not happily co-exist
with PonyProg as they both use DLPORTIO.dll and DLPORTIO.sys but different versions of them.
3) Which "DAT" file to use for the 89S51?
Simply use REG51.dat
The 89S51 is functionaly the same as the older 89C51 but has an extra dptr reg and a watchdog timer which is disabled by default.
If you need these extra features download the data sheet, get the register details and enter them into REG51.dat and save it under another name such as 89S51.dat
4) Other utilities
Atmel also has available for free download the following 2 programs which are handy:
A Intel hex to bin file convertor
www.atmel.com/dyn/resources/prod_documents/HEX2BIN.EXE
and the other way round
www.atmel.com/dyn/resources/prod_documents/BIN2HEX.EXE
I have been using this arrangment for a few weeks now and it works a treat.
The software is a bit tricky at first to get used to but you will soon get the hang of it.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
