Joined: 25 May 2004 Posts: 190 Location: Ljubljana, Slovenia
Posted: Sun Feb 27, 2005 6:17 pm Post subject: Multipleclick on key
Doubleclick.
Everybody understands doubleclick on computer mouse. Something like that I am trying to achieve on my micro.
First I need a timing mashine to measure time delay in which the second click shoud reappear if doubleclick function is to be proccessed. So I start timer like this:
' 1 second = 1000000 usec = 32 (mod=0) x 250 (load timer) x 125 (Ticnt) ConfigTimer0=Timer , Gate=Internal , Mode=0 OnTimer0 Titi
LoadTimer0 , 250 EnableTimer0 StartTimer0 EnableInterrupts
So timerinterupts will apear 125 times in one second. I count them in Timer interrupt routine:
Titi: LoadTimer0 , 250 If Ticnt <255Then Incr Ticnt
If Ticnt =50Then Set Clickflag 'set flag time interval elapsed Incr Ticnt 'to be sure, that clicflag set 'only ones for the time End If Return
As you can see, I count the interrupts only until the byte Ticnt is full ( 255) and when counter reaches no 50, I set a flag.
Everytime click appears, I reset counter Ticnt. If second click appear before Ticnt reaches 50, no Clickflag is set in the counter is set to zero again. Not before 50/125 second after last click the Clicflag is set.
Each click resets Ticnt and is registered in counter Clickcnt:
' somewhere in main program loop i test if key pressed: Debounce Key , 0 , Clicksr , Sub
Clicksr:
Ticnt =0 Incr Clickcnt
I proccess the click in the main program loop after Clicflag is set:
' somewhere in main program loop If Clickflag =1Then Reset Clickflag
Cls
SelectCase Clickcnt
Case1:Lcd"Singleclick" Case2:Lcd"Doubleclick" Case3:Lcd"Tripleclick" CaseElseLcd"Multipleclick" Locate2 , 1 Lcd Clickcnt
EndSelect
Clickcnt =0'reset clickcounter End If
