IR-decoder NEC, Samsung, Toshiba.
Mrshilov
Bascom LCD Guru
PostPosted: Sat Jul 11, 2015 12:52 am    Post subject: IR-decoder NEC, Samsung, Toshiba. Reply with quote
IR-remote protocols NEC, Samsung and Toshiba are very close. This subroutine decode it all.
Address & Command bytes is ready received data,
Ir_receive bit indicate a received data,
Ir_repeat bit indicate a repeat key for NEC or Toshiba. Samsung has not special repeated key - transmitted whole data again.
Ir_error bit may be used to recognize receiving error.
Ir_protocol = 1 for NEC,
Ir_protocol = 2 for Samsung or Toshiba.
Subroutine is adaptive, so IR clock could go beyond the standard and AVR clock may be from 1 to 64 MHz - you can even change the frequency on the fly.
In attachment example with SSD1306 LCD.
PostPosted: Mon Jul 13, 2015 10:53 pm    Post subject: Reply with quote
ha, super ! A big frequency range and lot of protocols.
Thank you for sharing.
aphawk
PostPosted: Tue Jul 14, 2015 6:02 pm    Post subject: Reply with quote
Mrshilov,
Thank you, is a very nice program, with a new approach, I like this solution, without frequency clock problems, and the best : multi-protocol !
Paulo
