Luciano
Posted: Mon Sep 06, 2010 7:05 am Post subject: |
Works here. (See attached picture).
Verify your hardware.
Best regards,
Luciano
Used code:
Code: | $regfile = "attiny2313.dat"
$crystal = 8000000
$lib "LUC_lcd4busy.lib"
Const _lcddb4_portx = Portd
Const _lcddb4_ddrx = Ddrd
Const _lcddb4_pinnumber = 2
Const _lcddb5_portx = Portd
Const _lcddb5_ddrx = Ddrd
Const _lcddb5_pinnumber = 5
Const _lcddb6_portx = Portd
Const _lcddb6_ddrx = Ddrd
Const _lcddb6_pinnumber = 4
Const _lcddb7_portx = Portd
Const _lcddb7_ddrx = Ddrd
Const _lcddb7_pinx = Pind
Const _lcddb7_pinnumber = 3
Const _lcde_portx = Portd
Const _lcde_ddrx = Ddrd
Const _lcde_pinnumber = 1
Const _lcdrw_portx = Portd
Const _lcdrw_ddrx = Ddrd
Const _lcdrw_pinnumber = 6
Const _lcdrs_portx = Portd
Const _lcdrs_ddrx = Ddrd
Const _lcdrs_pinnumber = 0
Config Lcd = 16 * 2
Cursor Off Noblink
Cls
Lcd "12345678"
Locate 2 , 1
Lcd "87654321"
Waitms 1000
Cls
Waitms 500
End |
Ross_ValuSoft
Joined: 20 Nov 2005 Posts: 275 Location: Melbourne, Australia
Posted: Tue Sep 07, 2010 2:35 am Post subject: |
Hello Luciano,
Completely unrelated ... why do you have wood in the sockets?
Cheers,
Ross |
Luciano
Posted: Tue Sep 07, 2010 7:49 am Post subject: |
(This post is an out of topic).
Hi Ross,
The three attached pictures should be self-explanatory.
Note that this solution has an impact if you use a top adapter like the STK501.
(You will have to extend the length of the male header connectors of the STK50x adapters).
Best regards,
Luciano |
Aleksandr
Joined: 29 Jul 2010 Posts: 15 Location: Russian Federation
Posted: Tue Sep 07, 2010 11:21 am Post subject: |
You need to use ZIF-socet.
Remove set socets, and solder ZIF.
Enough space for them? |
Luciano
Posted: Tue Sep 07, 2010 12:42 pm Post subject: |
There is no space for ZIF sockets. One ZIF will interfere with another
ZIF and the lever of the ZIF will interfere with the port headers or, if
you turn it, the lever will interfere with the jumpers or ISP headers of
the STK500.
(The gap space between the original DIP sockets of the STK500 is 4mm).
Best regards,
Luciano |
radciprian
Joined: 23 Oct 2010 Posts: 8 Location: Cluj-Napoca, ROMANIA, EU
Posted: Sat Oct 23, 2010 10:40 pm Post subject: LCD Problem |
Hy Luciano, i have an EA W162B-BNLW LCD model 16x2 (http://www.lcd-module.de/pdf/doma/blueline-w.pdf). Datasheet tells me that the controller is HD44780. I have connected the LCD as follows:
LCD AVR ATMega8
' pin pin
' Db4 = PD3
' Db5 = PD2
' Db6 = PD1
' Db7 = PD0
' E = PD5
' RW = PD7 'Note that RW must be connected to a pin!
' RS = PD6
I used your library example (to try the busy flag) and other combinations to init the LCD but every time i get in the first row black boxes. I have also attached another LCD to the board an it's working well. This LCD does not want to init and i don't know what can be the problem. |
Luciano
Posted: Sun Oct 24, 2010 10:43 am Post subject: |
From the web page: LINK
The dot-matrix LCDs offered here are all equipped with
the HD 44780 controller or similar.
Open the datasheet of the controller chip soldered on your LCD module
and then verify if the initialization sequence and timing are compatible
with the initialization routine present in the file LUC_lcd4busy.lib.
If not, feel free to modify the code in the library.
My code was tested with an original Hitachi chip HD44780 and
other compatible chips.
Best regards,
Luciano |
radciprian
Posted: Sun Oct 24, 2010 1:57 pm Post subject: |
The controller is HD44780, but i cannot init the LCD, nothing appears on the rows. At full contrast the first row is black and nothing happens. After reset, there is a short changing in the intensity of light on LCD, but nothing happens. It's possible to need a negative voltage at contrast pin?
Here is the code
Code: |
$regfile = "m8def.dat"
$crystal = 11059200
$hwstack = 32
$swstack = 16
$framesize = 40
Const _lcddb4_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb4_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb4_pinnumber = 3 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb5_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb5_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb5_pinnumber = 2 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb6_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb6_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb6_pinnumber = 1 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb7_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb7_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb7_pinx = Pind 'Valid values: PINA, PINB, PINC, PIND, PINE.
Const _lcddb7_pinnumber = 0 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcde_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcde_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcde_pinnumber = 5 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcdrw_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcdrw_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcdrw_pinnumber = 7 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcdrs_portx = Portd 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcdrs_ddrx = Ddrd 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcdrs_pinnumber = 6 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Config Lcd = 16 * 2
Cls
Waitms 1000
Lcd "1234567890"
Locate 2 , 1
Lcd "1234567890"
!NOP
Luciano
Posted: Sun Oct 24, 2010 3:35 pm Post subject: |
Based on your question, I assume that your LCD not only doesn’t work with my library
but also with the standard LCD routines of Bascom. (CONFIG LCDPIN = PIN ....).
If this is the case, please open a new thread in the appropriate forum section.
Best regards,
Luciano |
sunmat
Posted: Wed Dec 08, 2010 7:32 am Post subject: Proteus problem |
Hi Luciano....
This is great code, THANK YOU.
Unfortune I can't test in real hardware yet, but I want to inform you that code is norking with in Proteus. I'm in office now, and can't send you code and project, but could you test in, and see where can be a problem.
As remember Proteus complain about sending command when LCD is still busy. And I see that MCU constantly sending some some data to LCD.
I connected RW pin regulary.
Regards! |
Luciano
Posted: Wed Dec 08, 2010 5:42 pm Post subject: Re: Proteus problem |
sunmat wrote: | As remember Proteus complain about sending
MCU constantly sending some some data to LCD. |
This is normal, the code in the LIB checks the busy flag of the LCD
over and over until it is cleared by the LCD. Have a look at the code
I am not a Proteus user.
Best regards,
Luciano |
sunmat
Posted: Wed Dec 08, 2010 7:49 pm Post subject: .... |
Quote: | I am not a Proteus user.. |
ccc
I have fix a problem. So anyone who try this routines with Proteus have to change LCD clock from 240kHz to upper values. In my case to 1000kHz for 8Mhz CPU speed. |
sunmat
Posted: Wed Dec 08, 2010 8:32 pm Post subject: DEL.... |
Sometimes it is necessary to delete last character on LCD. Eg. in serial terminal when chr( is received from PC.
Maybe you can add this feature to your LCD routines as option?
Const DEL_enable=0 ' Valid values: 0,1
Const DEL_chr = 8 ' Valid values:0-255
Regards ! |
Luciano
Posted: Wed Dec 08, 2010 8:47 pm Post subject: |
To delete one character, more characters or the last character, you
just need to use the Bascom command LOCATE to move the LCD
cursor to the desired location and then use LCD " " to send a space
character to the LCD which will override the character that need to be
deleted.
In my library are only low-level routines which are called
by the Bascom compiler.
Best regards,
Luciano |
sunmat
Posted: Wed Dec 08, 2010 9:02 pm Post subject: ... |
Quote: | ...use the Bascom command LOCATE to move the LCD
cursor to the desired location and then use LCD " "... |
Yes, I know that, but how to find out current LCD cursor Row and column location?
