Libray for character LCD modules (Busy flag/random pins)
Goto page Previous  1, 2, 3, 4, 5  Next
Plons
PostPosted: Sat Jul 12, 2008 3:14 pm    Post subject: Reply with quote
Very good. I tried the code you posted, Luciano. Except for the MCU, since I use a M168.
The result: in the picture
So what is going on ? When I do a manual reset, the result is OK. When I come from a power-down situation, it doesn't.
I have to sort that out. It has to do with the OLED. The AVR generates (using PWM) the contrast voltage. When that voltage is (too) low, something goes wrong in the initialization.
What I can confirm now: Luciano is right, the "Config lcdpin etc"-statement is not needed to make LUC_lcd4busy.lib work. But for the OLED I do need it. I will sort it out and let you know.
Thanks for the support !
Nard
Bascom AVR ver 2.0.8.1
ProtectedParallelPortProgrammingDongle: http://www.aplomb.nl/TechStuff/PPPD/PPPD%20English.html
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel"
Plons
PostPosted: Sat Jul 12, 2008 4:05 pm    Post subject: Reply with quote
This is a tough one.
I modified the hardware to ensure that the Contrastvoltage is 5V at power on. It didn't do a thing .... Sad
Added wait-statements in several places ... just to sort out what would cure the effect: no deal ....
But: a re-init of the OLED does the trick (just a code-fragment shown here, the rest is as shown in previous posts))
Config Lcd = 20 * 2
Cursor Off Noblink
Cls
Gosub _init_lcd
LCD "Line 1 1234567890123"
Locate 2 , 1
Lcd "Line 2 1234567890123"
 !NOP
So I found a cure, but still don't understand the cause of the phenomenon.
(Note: found a problem in the fuse-setting: the boot-vector was enabled .... instead of the reset-vector. But oh well, it wasn't causing the problem, but still ... I should have noted it before)
Nard
Plons
PostPosted: Sun Jul 13, 2008 12:51 am    Post subject: Reply with quote
I removed the pull-downs on E and R/W ....
Supply the board from a lab-supply ...
Increased delays in luciano's lib .....
Updated Bascom to 1.11.9.2 ...
... and learned a bit more: that Config lcdpin in Options - Compiler - LCD is not as harmless as I (and maybe you ... ) thought: when not overruled by a Config lcdpin in the program, it still sets the DDR-bits as dictated by the Options - Compiler - LCD - setting. Yikes. Never realised that ....
I discovered it because the OLED contrast should be fine even when the PWM-output-pin is configured as input. But the OLED was very dim. (not in the pictures btw)
So: I am stuck. Puzzled. Can fix it with that extra Gosub _init_lcd, but would like to know the WHY ...
I have some other LCD's, but need to make a different cable for those. Sounds like a sundaymorning thingie.
Cheers !
Nard
Luciano
PostPosted: Sun Jul 13, 2008 12:56 pm    Post subject: Reply with quote
Hi Nard,
The routine "_Init_LCD" present in LUC_lcd4busy.lib will set the data
direction of the used pins. The routine _Init_LCD is called when you
call the first LCD command in your code. (In my sample, Cursor Off Noblink).
The routine _Init_LCD present in LUC_lcd4busy.lib overrides the settings
present in the Bascom Options-Compiler-LCD whatever they are.
At power-up, during the hardware initialization performed by the Bascom
initialization code, the data direction of the pins selected from
"Options/Compiler/LCD" is set. To avoid that, just select the radio
button "Data mode = bus". By doing that, no data direction register will
be changed by the Bascom initialization code to support the LCD so that
you will save some program space. If you go back to the Bascom internal
LCD routines, then you must remember to set "Data mode = pin".
Again, the routine _Init_LCD present in LUC_lcd4busy.lib overrides the
settings present in the Bascom "Options/Compiler/LCD" whatever they are.
Best regards,
Luciano
Plons
PostPosted: Sun Jul 13, 2008 4:25 pm    Post subject: Reply with quote
Finally, finally ....
I had an original HD44780 display, 16*2, and that showed the same problem. And that made no sense. The OLED has a clone of the 44780, so I could imagine some incompatibility there. But this old display should work !
I took another AVR-board, and tested with *several* displays. They all worked fine.
So what is wrong with the OLED-controllerboard ?? It's a straight forward design, in which I had connected the lower datalines D0 - D3 to ground.
And that caused this weird behaviour !!
Mystery solved. Thanks for your support, Luciano. Since PM is disabled on this forum, would you pls. contact me on "2 times my nickname here, no spaces, no capitals, the curl, and then gmail etc" Not to ask you for more support, just want to send you a present.
Nard
Luciano
PostPosted: Sun Jul 13, 2008 6:58 pm    Post subject: Reply with quote
Hi Nard,
You're welcome!
Your "thank you" was more than enough.
Best regards,
Luciano
enniom
PostPosted: Thu Oct 22, 2009 2:55 pm    Post subject: LUC_lcd4busy ... a question Reply with quote
Luciano,
After all this time, lcd_busy is still one of the most innovative solutions for working with LCD's. Congratulations.
If I wanted to use lcd_busy to drive a 40*4, would that be as simple as toggling the E2 line separately via a program-based PORT/PIN Set/Reset just prior to sending the Lcd "Text" command - or - would that interfere with the E toggle built into the lcd_busy.lib?
If the approach above is not possible, how difficult would it be to modify lcd_busy.lib to include the E2 toggle function?
Grazie.
Ennio
Luciano
PostPosted: Sun Oct 25, 2009 2:14 pm    Post subject: Reply with quote
Hi Ennio,
it should be quite simple to write a library which checks the state of the busy flag of an
LCD with two HD44780 controllers (4x40 LCD). See the original Bascom libraries "Lcd4e2.lib"
and "lcd4busy.lib".
If you have questions about how to do that, please start a new thread in an appropriate section
of the forum.
Here is a sample how to use the Bascom library "Lcd4e2.lib".
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&p=31687#31687
(Busy flag not used).
Best regards,
Luciano
Neill
PostPosted: Sun Jan 31, 2010 11:10 am    Post subject: Thanks very Much. Reply with quote
Thanks so much Luciano for your library. It has helped me very much.
Writing to a 4 line by 20 char display is now very fast and means that I can have real time events happening exactly when I need them to, every 50mS and I don't have to worry about how long it is taking to update the LCD.
Grazie,
Neill
Aleksandr
PostPosted: Sun Aug 01, 2010 6:50 pm    Post subject: Reply with quote
Hi, Luciano!
For me does not work "LUC_lcd4busy.lib".
In what a problem?
My code:
$crystal = 8000000
$regfile = "m8def.dat"
$hwstack = 64
$swstack = 40
$framesize = 40
Dim X As Byte
$lib "LUC_lcd4busy.lib"
Const _lcddb4_portx = Portb                                 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb4_ddrx = Ddrb                                   'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb4_pinnumber = 0                                 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb5_portx = Portd                                 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb5_ddrx = Ddrd                                   'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb5_pinnumber = 7                                 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb6_portx = Portd                                 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb6_ddrx = Ddrd                                   'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb6_pinnumber = 6                                 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcddb7_portx = Portd                                 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcddb7_ddrx = Ddrd                                   'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcddb7_pinx = Pind                                   'Valid values: PINA, PINB, PINC, PIND, PINE.
Const _lcddb7_pinnumber = 5                                 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcde_portx = Portd                                   'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcde_ddrx = Ddrd                                     'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcde_pinnumber = 1                                   'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcdrw_portx = Portb                                  'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcdrw_ddrx = Ddrb                                    'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcdrw_pinnumber = 3                                  'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _lcdrs_portx = Portb                                  'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _lcdrs_ddrx = Ddrb                                    'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _lcdrs_pinnumber = 2                                  'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Config Lcd = 16 * 2
Cursor Off Noblink
Main:
Cls
Lcd "Line 1 1234567890123"
Locate 2 , 1
Waitms 2000
Goto Main
Ross_ValuSoft
PostPosted: Mon Aug 02, 2010 11:37 am    Post subject: Reply with quote
Do you realise that you are trying to write a 20 character string onto a 16 character screen?
Also ... see if allowing the screen to clear first helps.
Cls
waitms 500
Locate 2 , 1
Waitms 2000
Cheers,
Ross
Luciano
PostPosted: Mon Aug 02, 2010 5:35 pm    Post subject: Reply with quote
Before testing your program, make sure you disconnect the ISP programmer first.
(The ISP programmer uses the pin PB3).
Best regards,
Luciano
Aleksandr
PostPosted: Mon Aug 02, 2010 6:03 pm    Post subject: Reply with quote
Thanks, Ross_ValuSoft. Why I have not guessed?)))
Luciano, I certainly disconnect isp prrogrammer.
Thanks all for the help
Frankeman
PostPosted: Mon Aug 02, 2010 7:28 pm    Post subject: Reply with quote
Write a little test program that toggles every used pin which is connected the the LCD.
Do this pin by pin and measure al the connections on the display.
This way you are sure that every connection is correct and a short circuit can be found.
Aleksandr
PostPosted: Mon Aug 02, 2010 8:00 pm    Post subject: Reply with quote
Frankeman, i used multimeter for testing connection to LCD.
All connections is good. Changed controllers, without result.
There are at someone else ideas? Idea
May be "LUC_lcd4busy.lib" not for all kontrollers?
Mr.Luciano! On what controllers you have checked up "LUC_lcd4busy.lib"?
Best regards
Page 2 of 5
