DIM or LOCAL
dw
PostPosted: Thu Feb 24, 2005 9:31 am    Post subject: DIM or LOCAL Reply with quote
Declare Sub Foo
Foo
Sub Foo
Dim Long_a As Long
Local Long_b As Long
Local Word_c As Word
Word_c = Long_a / 2                                         ' OK: Global Long Var used
Word_c = Long_b / 2                                         ' ERROR: Local Long Var used
End Sub
When using the local long variable you got a 242 Error (Source does not match taget var)
Using the global one is ok
Does any one knows why? Bug or feature?
Thanks for help!
Cu, Dw
oe9vfj
Moderator
PostPosted: Thu Feb 24, 2005 10:31 am    Post subject: Reply with quote
Mixing Long and Word variable in one operation isn't supported (yet), when they have different scope (Local, or Global)
regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel
