Hand Soldering ATMEGA Chips
51Magnum
PostPosted: Fri Jul 27, 2007 4:38 pm    Post subject: Hand Soldering ATMEGA Chips Reply with quote
Hello,
Can anyone tell me if I should be concerned about hand soldering a ATMEGA168 in a 32-TQFP package. I guess my real question is the moisture. It has come in a moisture barrier bag that says I should bake it prior to vapor or IR soldering.
I am comfortable soldering it by hand I would like some advice on the moisture part of it.
Thanks
Shane
Luciano
PostPosted: Fri Jul 27, 2007 5:27 pm    Post subject: Reply with quote
Read Section 3, pages 63 64, 65 and 66.
http://www.onsemi.com/pub/Collateral/SOLDERRM-D.PDF
Best regards,
Luciano
51Magnum
PostPosted: Sat Jul 28, 2007 3:21 am    Post subject: Reply with quote
Luciano,
thanks for that document, it gave me some insights but I am hand soldering and I am not sure how much of a difference that makes.
I am at a loss. I have soldered chips for a long time and I have recently tried to solder the TQFP. I have good solder joints on all the pins but in both cases I can not communicate with the uP. The first one I did about 6 months ago. It was a 2561 and today I tried the 168. What is the deal? I have checked the pins to make sure I have the correct voltages and gnds hooked up but I can not communicate with the 168.
for information I have used the 168 in the DIP configuration and have had great success but not with the TQFP.
Thanks
51Magnum
PostPosted: Sat Jul 28, 2007 4:16 am    Post subject: Reply with quote
ok, I figured it out. The SCK pin was not soldered correctly Embarassed . I am glad it was something simple!
Thanks for your help.
